ᐅ How can I best install Ikea Metod kickboards with underfloor heating?
Created on: 21 Aug 2022 19:47
Arcado
Arcado
21 Aug 2022 19:47
Hello everyone, I am currently planning to install the Ikea Metod kitchen plinths at home, but I am facing a challenge because our floor has underfloor heating.
My main question is: What is the best way to fix the Ikea Metod plinths to a floor with a heating system so that they hold securely without causing any damage to the underfloor heating?
I understand that when dealing with underfloor heating, special care needs to be taken during installation to avoid damaging pipes or sensors and to ensure the heat distribution is not affected.
Which fixing methods would you recommend? Are there specific anchors or adhesives suitable for this? Or is mechanical fixing still advisable despite the underfloor heating?
Also, I am interested in advice on how to adjust the plinths in relation to the heating circuit, for example, the distance from the floor or special profiles that allow better air circulation.
I look forward to your tips and experiences!
Gafiel
22 Aug 2022 09:32
Hello Arcado,
First of all, I think your question is very well formulated and important because many underestimate that fastening baseboards on underfloor heating can affect the efficiency of the heating system.
Generally, I advise against using conventional anchors or nails in such situations, as they could damage the heating pipes embedded in the screed if you accidentally drill in the wrong spot. This applies especially to mechanical fastenings.
Here are some specific recommendations:
- Always check with a cable and pipe detector where the lines run before drilling or using nails.
- For Ikea Metod baseboards, special adhesive baseboards or mounting adhesives that are highly heat-resistant and provide enough hold without damaging the floor are suitable.
- There are also flexible, elastic mounting sealants (e.g., MS polymer adhesives) that work well for this type of baseboard.
- Make sure the adhesive is suitable to withstand the stress from possible movement of the baseboard, especially with temperature changes.
Regarding air circulation: The baseboards should always have a small gap from the floor (2–5 mm (0.08–0.2 inches)) to allow natural air circulation, which helps distribute heat optimally and minimize moisture.
If you prefer mechanical fastening, I recommend:
- Instead of using anchors in the floor, fasten the baseboard to the wall, for example with screws into the wall or special brackets mounted on the wall to which the baseboard can simply be hooked.
What is the situation like at your location? Is it a screed with direct heating or a dry construction method? That could influence the best method to use.
roryvin
22 Aug 2022 14:07
Gafiel schrieb:
Regarding air circulation: Baseboards should definitely have a small gap from the floor (2-5 mm), to allow natural air circulation, which helps distribute heat efficiently and minimize moisture.
This is a very important point that I want to emphasize again here. Especially with underfloor heating, air must be able to circulate; otherwise, heat buildup and even damage to the floor covering can occur.
Furthermore, I generally recommend the following approach:
- Avoid drilling directly into the screed or floor.
- Use adhesive baseboards, fixed with a high-quality, temperature-resistant mounting adhesive.
- Before installation, check the underfloor heating system, ideally with plans or markings, to avoid damaging heating pipes.
In addition, choose a mounting adhesive that does not release harmful fumes after curing and, if possible, remains flexible to compensate for temperature-related movements.
Mechanical fasteners to the wall are secure if the furniture installation allows it.
Finally, a tip: Some manufacturers already offer specially designed mounting systems for baseboards with underfloor heating that combine adhesion and hooking. This can ensure easy and reversible attachment.
PEDRO40
23 Aug 2022 10:19
Arcado schrieb:
How can I best attach the Ikea Metod baseboards on a floor with an underfloor heating system so that they hold securely without causing any damage to the heating system?
I can completely understand that finding a secure yet gentle solution is important to you. Underfloor heating is great, but it’s natural to worry about damaging it.
I recently did something similar and can share my experience: I chose a combination of adhesive and a slight snap-fit. It was important to me not to drill, but to use a strong yet flexible adhesive that has proven reliable in everyday use. The baseboards hold very firmly, yet I can still remove individual sections if needed.
What also helped was carefully checking the exact location of the heating pipes beforehand and cutting the baseboards accordingly. It was also crucial not to press the entire surface of the baseboard flat against the floor, but to install them so there is a slight gap behind the board, allowing for air circulation.
I also find a small air gap at the floor essential, as others have mentioned. This keeps everything breathable and ensures effective heat transfer.
If you like, what type of adhesive or system are you currently working with? Maybe I can offer more specific advice.
