ᐅ How can I modify Ikea Metod cabinets for an accessible kitchen?
Created on: 26 Apr 2024 08:43
padanGood morning everyone,
I am currently exploring how to modify Ikea Metod kitchens or cabinets in a practical and effective way to create an accessible kitchen. Specifically, I am interested in adaptations that make the cabinets, which are usually designed for standing users, more accessible for people with limited mobility, such as those using a wheelchair.
I am looking for ideas and experiences on how to modify the cabinets so that they are easier to reach, provide sufficient knee clearance underneath, or allow for ergonomic adjustments to the fronts and internal fittings. What options are there for changing the installation height, internal drawers, or doors in Metod systems to make them accessible?
Additionally, I am interested in how standard fittings, drawer sizes, or possibly electrical drives can be integrated to further improve comfort.
I look forward to your tips, recommendations, and practical experiences! Thank you in advance.
Hello padan!
This is a great topic, especially since accessible kitchens are becoming increasingly important. I’ve personally modified several Ikea Metod cabinets and can share a few tips!
- I usually raised the base cabinets and used sturdy adjustable legs that can be manually fine-tuned. This creates more knee clearance space underneath.
- I often replaced drawers with internal pull-outs, as they are easier to access than doors with shelves inside.
- For the fronts, you can easily swap traditional handles for handleless cabinets with push-to-open mechanisms that open with a simple hand press.
- Even better are electric opening systems. Ikea doesn’t offer these directly, but you can install external electric fittings, making operation as easy as pushing a button.
Of course, it’s sometimes a challenge because Metod cabinets are not originally designed to be fully accessible, but with a bit of creativity, it works really well! Keep it up, it’s worth the effort!
Hello padan,
your question addresses a key aspect of many modern kitchen designs: how to adapt standardized cabinet systems to improve accessibility. Let me explain in more detail:
- First, it is important to clarify the user profile: wheelchair user, limited grip strength, difficulty standing? The optimization varies depending on the target group.
- Generally, I recommend setting the base cabinets to a height of at least 85-90cm (33-35 inches) to ensure enough legroom. This is achieved by replacing the kickboards with sturdy, load-bearing adjustable feet. Height-adjustable options are ideal.
- It makes sense to replace drawers with fully extendable inner drawers equipped with smooth-running hinges and soft-close systems to make access easier.
- Front panels with push-to-open or electronically assisted opening mechanisms help users with less strength or limited mobility.
Important: When remodeling, always follow the accessibility standards according to DIN 18040-2. This ensures not only comfort but also compliance with regulations.
I would be interested to know the exact measurements your users need to provide more targeted advice. How much structural space do you have available for your cabinets? Which operating methods do you prefer?
Looking forward to more details to offer practical suggestions!
Surela schrieb:
Important: When renovating, the DIN standards for accessibility (DIN 18040-2) should always be followed.Absolutely correct – the standard provides clear requirements, such as minimum legroom dimensions (at least 30 cm depth and 70 cm height under the countertop).
The Metod system can be adapted as follows:
- use taller adjustable legs to raise the standard 80 cm cabinets to at least 85–90 cm
- opt for internal drawers instead of doors, as they are easier to access
- electronic opening mechanisms can be installed as retrofitting options
Important: When planning, also consider ease of use for people with limited grip strength, for example by replacing knobs and handles with large, easily reachable ones, or by using handle-free operation with tip-on technology.
For Ikea Metod systems, I also recommend choosing modular solutions so the kitchen can be easily expanded or adapted if needed.
