ᐅ How can I install IKEA Metod cabinets precisely under sloped ceilings?
Created on: 22 Apr 2021 08:17
sefaris
I am planning to install IKEA Metod kitchen or cabinet units in my bedroom under a sloped ceiling and I’m a bit unsure about how to modify these cabinets so they fit perfectly and remain stable. My sloped ceiling is quite steep and irregular, so the standard cabinet setup doesn’t really work. I’m wondering how to cut and install the cabinet sides, shelves, or panels to achieve a perfect fit without large gaps or unsightly spaces. Are there any proven techniques, tools, or special adjustments you would recommend? I’m also interested in solutions for fastening the cabinets to the angled wall or ways to compensate for uneven floors. I want to avoid sloppy work later on or compromising the stability of the cabinets. How have you handled this or what tips can you share? Thanks in advance for your support!
Hello sefaris,
I know the feeling when the perfect installation is made more difficult by the sloping roof. For me, it was especially important not to get frustrated and to keep making small adjustments and careful measurements.
Exactly! I also made small surface-mounted trims to give the edges a clean finish. The cabinets under the slope then don’t look cramped, but like real pieces of furniture.
When attaching them, it helped me not only to screw the cabinets securely to the wall but also to stabilize them with the floor. That way, nothing wobbles.
Timmyse36 schrieb:
Encouragement: It’s possible, even if it’s annoying!
Thanks for the quick and helpful feedback so far! One more question: how did you handle the interior fittings for custom-cut cabinets? I mean the inserts or shelves, which are usually rectangular. Do you need custom-made components for these as well, or do you use standard items and adjust the exterior shape accordingly?
Timmyse3623 Apr 2021 08:15sefaris schrieb:
How did you handle the interior fittings for custom-cut cabinets? I mean the inserts or shelves, which are usually rectangular.That’s an important question! I usually sanded the shelves on the side that meets the angled wall so they fit the slope. When the angle was very sharp, I sometimes cut the shelves into a trapezoid shape.
You can also use adjustable shelves at the same time, which gives you more flexibility. Some people created simple measuring aids with wooden strips to determine the shape.
Adjusting from the outside is practical; inside, I tried to keep as much standard as possible, unless the angle was too extreme.
