ᐅ Protecting Billy Regal Shelves from Moisture – Any Tips?
Created on: 6 Feb 2020 08:14
geixan
I have a Billy bookshelf from Ikea that I want to place in the basement. The problem is that the basement tends to be damp, especially the shelves that rest directly on the floor. I’m concerned that the shelves might swell or get damaged due to the moisture. My question is: What is the best way to protect Billy bookshelf shelves from moisture?
I’m looking for practical advice to prevent the shelves from swelling, warping, or even developing mold. Has anyone had experience with special protective coatings, underlay mats, or construction-related measures? I’m also particularly interested in whether certain materials work better or if simply placing some kind of plastic sheet underneath is sufficient.
Thanks in advance for your tips!
meGreg
7 Feb 2020 10:12
To ensure effective moisture protection: Always consider air circulation right from the start!
posin50 schrieb:
A gap of about 2-3 cm (1-1.2 inches) works well to allow enough air to circulate.
Also, regularly open doors and windows in the basement (okay if it doesn’t bother anyone 😉) – this helps a lot. If possible, place a simple dehumidifier or some moisture-absorbing packets next to the shelving.
Clear varnish is great, but I would at least use a wood preservative primer under the topcoat – it’s a bit like sun protection for the wood and makes the surface more durable.
roryvin
8 Feb 2020 08:00
One more clarification: If the basement is very damp, it is worth using metal or plastic shelving instead of wooden shelves, as these materials are more resistant to moisture.
However, if the Billy shelf is to remain wooden, be sure to apply a sealed surface treatment and perform regular checks.
Additionally: Basements with a humidity level below 60% are ideal. This can be controlled with a dehumidifier.
Luciandi
8 Feb 2020 09:38
meGreg schrieb:
Also regularly open doors and windows in the basement (okay, if it doesn’t bother anyone 😉) – that helps a lot.
Exactly. Ventilation is often overlooked but essential.
Also, be careful to ensure the basement floor is properly dry. If you still have the option, building a small base from, for example, waterproof material under the shelf (such as PVC panels) can make a big difference.
For longer-term storage, I really recommend addressing the sources of moisture at their origin.
geixan
8 Feb 2020 12:15
Great, thanks for the detailed answers! I will try it like this:
- 3 cm (1.2 inches) clearance from the floor using plastic feet
- Sand the shelves and seal them with a waterproof polyurethane-based clear varnish
- Regularly ventilate the basement and get a dehumidifier
If I get replacement shelves made of MDF, I also want to treat them with wood preservative beforehand. One more thing I'm curious about: Can the shelves be wiped with damp cloths without damaging the sealant? Or should they ideally be cleaned dry?
chenValeri
8 Feb 2020 13:09
Floors sealed with clear varnish can be carefully cleaned with a damp cloth. Dust and light dirt should preferably be removed dry or with only a slightly damp cloth. Avoid prolonged soaking.
