ᐅ How do I install Ikea Metod cabinets on tiled walls?
Created on: 9 Nov 2016 08:37
Gaudan
I am planning to install Ikea Metod kitchen cabinets directly onto tiled walls in my new kitchen. My main concern is how to securely fasten the cabinets to the wall without damaging or cracking the tiles.
The wall itself is made of brick, but the tiles appear to be quite thin and the grout lines are narrow. I want to avoid cracks or breakage caused by drilling into the tiles, as repairs would be costly.
Are there any special drilling techniques, anchors, or methods you would recommend for mounting Metod cabinets on tiled walls?
I would like to know
- which drill bits I should use,
- whether it is better to drill into grout lines or tiles,
- which type of anchors work best, and
- how to best distribute the load.
Thank you very much for your tips and experiences!
Rosan
9 Nov 2016 14:13
Chemical anchors are effective when the tiles are thin and you want to avoid cracks.
Pre-drill with a small glass drill bit, then blow out the hole. Do not use too much adhesive.
Only drill the tiles very lightly, without high rotation speed.
LAYNE
9 Nov 2016 16:10
RUBEN54 schrieb:
An advantage of chemical anchors is better load distribution and the elimination of expansion forces – especially beneficial for thin or delicate tiles.
That’s true, and I’d like to add: When installing Metod cabinets, you can even discuss this with a skilled kitchen installer, who usually has advice on the best type of anchor to use. By the way, chemical adhesive anchors are now also available in fast-curing versions, so you don’t have to wait forever.
It’s great to see so many tips coming together here—this is what makes the community fun! 😉
ronAlberto
10 Nov 2016 09:51
To explore the topic in more detail:
For installing Ikea Metod cabinets on tiled walls, a systematic approach is very important:
- First, precisely mark the exact position of the cabinets on the wall.
- Drill with a tile drill bit (ceramic/glass) at low speed (around 300-500 rpm), applying light pressure and no hammer action.
- Once the drill bit has passed through the tile, switch to a masonry drill bit with SDS shank or an appropriate bit for brick to drill deeper into the wall.
- Chemical anchors provide an optimal connection, especially for tiles and bricks, as they do not rely on expansion force.
- Make sure the chemical anchor material is fully cured before applying any load, which usually takes 6-12 hours.
- For load distribution: An additional mounting bracket installed at the bottom of the cabinet can reduce the load if space allows.
I would avoid attaching to grout lines, as the load is often less well supported there and grout tends to be more brittle than the tiles themselves.
Additionally: Always check in advance with a stud finder or ultrasound detector to ensure there are no hidden cables or pipes behind the wall to prevent damage.
Samir
10 Nov 2016 11:07
ronAlberto schrieb:
Chemical anchors provide an optimal connection, especially with tiles and bricks, since they do not rely on expansion force.
That is the crucial point.
I definitely recommend chemical anchors for tiles when a very secure and long-lasting fixing is required.
For Metod cabinets, the wall load is distributed across several screws; however, it is still advisable to transfer the load optimally through the bricks and minimize the stress on the tiles.
Properly blow out the drilled hole, apply the adhesive evenly, and perform the installation after the curing time—these are the keys to success.
