ᐅ How do I securely mount IKEA Metod kitchen cabinets on concrete walls?
Created on: 28 Jun 2024 09:17
GANAPEO
Hello everyone, I am currently planning my new kitchen with IKEA Metod kitchen cabinets and face the challenge of securely attaching them to concrete walls. My main question is: which fastening materials and techniques are best suited to reliably mount the sturdy but heavy wall cabinets on a solid concrete wall?
I already have anchors and screws but am unsure whether standard expansion anchors or special heavy-duty anchors are recommended. I am also interested in how to properly support the weight across the entire distribution of the cabinets. Are there any tips for wall preparation, specific screw sizes, or special tools that I should definitely use?
Since this is a completely self-assembled kitchen, I want to avoid mistakes from the start. I appreciate any advice based on experience or proven practice!
I would like to add to the discussion with a structured guideline:
- For concrete walls when installing IKEA Metod kitchen units, frame anchors (M8 or M10) are preferred. Expansion anchors may loosen under load.
- Drill depth should be at least 10 cm (4 inches), diameter depending on the anchor, usually 10 or 12 mm (0.4 or 0.5 inches).
- Thoroughly blow out the drilled holes before inserting the anchors.
- The screw length should fully cover the length of the anchor and reach at least 6 cm (2.4 inches) into the anchor.
- Pay attention to the maximum load per anchor (usually between 80 and 150 kg (176 and 331 lbs), depending on the product).
- Mount the cabinets with at least two fixing points per cabinet, more for heavier units.
- Use a good drill with a hammer function and a bit suitable for concrete.
These recommendations are based on technical data sheets from fastening material manufacturers as well as practical installation experience.
KAULIS schrieb:
Drill depth at least 10cm (4 inches), diameter depending on the anchor, usually 10 or 12mm (0.4 or 0.5 inches).I can confirm that. It is also important not to blow out the holes with compressed air, but to clean them with a brush or vacuum cleaner. The correct fit of the anchors is crucial.
GANAPEO schrieb:
Are there any tips for wall preparation, specific screw sizes, or special tools I definitely should use?Hey, regarding preparation: Make sure the wall is clean, dry, and dust-free – otherwise even the best anchors won’t hold well.
For tools, a good hammer drill with a suitable masonry bit and a vacuum cleaner to clean out the drill holes are worthwhile.
M8 screws with a length of 8–10cm (3–4 inches) are ideal. And yes, using torque control on your cordless drill is really valuable; otherwise, things can get damaged quickly.
Good luck with the screwing, the kitchen will look great! 😊
dijan schrieb:
Good luck with the screws, the kitchen will be great! 😊I second that! And remember: stay relaxed during assembly, or the wall might be the first to make some noise. 😉
Maybe GANAPEO can share how it went, I’d be interested!
