Hello everyone, I have a problem with my IKEA Metod kitchen base cabinets where the drawers make an annoying squeaking noise when opening and closing. It sounds like the runners are either not properly lubricated or slightly worn. I suspect the issue might be with the metal guide, but I don’t know the exact technical details. My question is: How can I effectively and permanently eliminate this squeaking from the IKEA Metod drawers? Are there specific maintenance methods, suitable lubricants, or parts that should be replaced? I would appreciate a detailed guide so I can fix the problem myself without having to disassemble everything. Thank you in advance!
ronAlberto1 Mar 2017 18:07Hello Lubill, your issue with the squeaking IKEA Metod drawers is quite common and usually has several causes you should consider. Basically, these drawers operate with roller slides that run on plastic or metal rollers. The squeaking usually occurs due to missing or worn-out lubricant on the tracks or small foreign objects getting stuck between the rollers and the slides.
To fix the problem, I recommend the following steps:
- Fully pull out and remove the drawers, which makes the work much easier.
- Visually inspect the tracks and rollers for dirt (dust, crumbs) or damage.
- Clean the tracks with a lint-free cloth and, if stubborn dirt remains, use a mild cleaning agent, but avoid harsh chemicals.
- Let the tracks dry thoroughly.
- Use a suitable lubricant: I recommend a silicone-based spray or Teflon spray, as these do not attract dust, unlike oil-based products.
- Apply the lubricant sparingly to the tracks and rollers, then open and close the drawer several times to distribute the lubricant evenly.
If the tracks or rollers are mechanically damaged (e.g., bent, worn), you should order replacement parts from IKEA as original parts and replace them. This is usually straightforward.
One important question: Are all the drawers affected or only certain ones? Sometimes it depends on the load or uneven installation. If you can confirm this, you might also want to check the alignment of the drawers.
If you can provide more detailed information (e.g., material of the guides, age of the kitchen), I can offer more targeted advice.
Hello Lubill,
I would like to summarize a simple step-by-step guide on how to effectively fix the squeaking in IKEA Metod drawers.
1. Remove the drawer: Pull the drawer out completely. Usually, Metod drawers have slide mechanisms that can be released by slightly lifting or unlocking the clips.
2. Cleaning: Remove all dirt and debris from the runners and rollers. A dry microfiber cloth works best. For stubborn grime, you can use a little dish soap with water but make sure to dry thoroughly.
3. Lubrication: Use a suitable lubricant. I recommend a sprayable silicone lubricant as it does not stick and does not attract dust. Apply a thin layer to all moving parts and the runners.
4. Reinstall and test: Put the drawer back in and open and close it several times to allow the lubricant to spread evenly.
5. Check: Pay attention to whether any noise continues. If so, check if the runner is bent or if the plastic block is worn. Replace the part if in doubt.
Note the following:
- Avoid oils or WD-40 as they can become sticky over time and attract dirt.
- Check the mounting parts, screws, and, if necessary, the drawer adjustment to ensure it runs smoothly.
If you follow these steps, the drawers should operate quietly and smoothly. If you like, I can provide tips on proper disassembly as well.
Note the following:
REOHEINRIC3 Mar 2017 09:51ronAlberto schrieb:
Basically, these drawers operate with roller rails that run on plastic or metal wheels.That is correct. Additionally, IKEA Metod drawers typically use ball-bearing slides with plastic rollers on metal tracks. The squeaking mainly occurs due to friction on dry or dirty bearing points.
tolokau schrieb:
I recommend a sprayable silicone lubricant because it does not stick and does not attract dust particles.I fully agree. Choosing the right lubricant is crucial for a long-lasting solution. Alternatively, Teflon spray also works well.
Based on my experience, the plastic rollers should be checked for cracks or hardening. If these are present, the rollers need to be replaced, otherwise the squeaking will return. Replacement is simple, and compatible spare parts are available from IKEA.
In summary:
- Clean the sliding rail
- Use silicone or Teflon spray
- Inspect and, if necessary, replace the rollers
- Check correct installation
This covers all relevant causes and ensures a sustainable solution.
