ᐅ How can I fix loose screws in Ikea Metod cabinets during assembly?
Created on: 4 Jan 2020 09:33
medraHello everyone,
I am currently assembling a kitchen using the Ikea Metod system and have the problem that some screws become loose or do not hold properly, even though I tighten them correctly. Specifically, I mean the wood screws often screwed into the side panels, as well as the connector fittings (shelf adapters and similar). I am interested in how to best fix or securely fasten these loose screws without making the furniture unstable or causing it to come apart later. Are there any specific tips or tools I should use? And how should I proceed if the material already feels somewhat softened?
I look forward to your tips and experiences, especially technical instructions or practical advice that can be easily applied during assembly.
Hello medra,
Your question is very relevant because the issue of loose screws in Ikea Metod furniture is quite common and can often be resolved effectively with some know-how. I would like to suggest a detailed approach:
- First, carefully check exactly where the screws are loose. Are they wood screws going into particleboard, or are they cam connectors or fasteners in metal/plastic?
- With particleboard, it is common for the material to be damaged when screws are repeatedly driven in, causing the screw to lose its grip.
- You can mix some wood glue with wood shavings (for example, from leftover cuttings) and fill this mixture into the screw hole. Then carefully reinsert the screw. This compacts the material and improves the hold.
- Alternatively, wooden dowels can be used: drill out the hole with an appropriate drill bit, insert dowel pieces, and then screw back in; this stabilizes the connection.
- For metal connectors, make sure the screws are tightened properly but without over-tightening. If the fixing point is fixed in size, you might try a different screw size or use a specialized anchor for reinforcement.
- It is important to always use a good-quality driver with the right size (cross-head or Torx screwdriver) to turn the screw cleanly and prevent slipping.
- If the material is softened or worn out, it can help to repair the holes with some epoxy resin and only drive the screw in after the resin has fully cured.
I would be interested to know if your holes are already too large or if the screw heads are breaking off. Perhaps you can provide more details? Then I can offer more targeted help.
Marion schrieb:
Loose screws can often be fixed by inserting a small piece of toothpick or wooden stick into the hole, which holds better.That’s a good tip, and I also recommend filling damaged screw holes first with a suitable wooden dowel or toothpick. You can additionally use wood glue to improve the holding strength.
It is important that the glue dries completely before re-inserting the screw. Otherwise, the strength will be lost again.
Furthermore, you should always make sure to tighten the screws with the correct torque to avoid excessive fraying of the particleboard.
If the material is already too soft, the only solution is to reinforce the hole or use metal or plastic anchors specifically designed for this purpose.
My advice: For Metod modules, it can sometimes be worthwhile to buy replacement fittings or stronger screws if you notice that the original ones do not hold.
I can really understand medra, problems like that during assembly are truly frustrating. It has also happened to me that screws don’t hold properly even when tightened carefully, which makes you unsure whether everything will be stable.
I have experienced that as well and unfortunately often noticed it too late.
I always try to stay calm and not give up right away. Sometimes it helps to unscrew the screw, clean the hole a bit (for example with a small screwdriver or toothpick, as Marion says), then drop some wood glue into the hole, let it dry briefly, and then screw the screw back in.
It is time-consuming, but in the end it gives me some certainty that the structure will hold.
What I find difficult, however, is finding the right balance when tightening, so you don’t overtighten.
Maybe you have some tips on how to develop a feel for that?
Laukau5 schrieb:
With particle boards, it is usually the case that the material gets damaged from repeated screwing in, and then the screw no longer holds firmly.
pinJustin6 Jan 2020 07:55Hello medra,
if the hole in the chipboard is too large, you can fix it with wood glue and wooden dowels. Simply insert dowels into the hole, add glue, then screw in the screw.
This provides a secure hold and prevents future problems. For metal connectors, all screws should be tightened properly using the appropriate screwdriver.
