ᐅ Which screws are suitable for assembling Ikea Metod base cabinets?
Created on: 5 Jan 2022 09:12
kainso
I am planning to assemble some Ikea Metod base cabinets and am currently in the process of ordering the appropriate screws. Unfortunately, I have noticed that the screws supplied often are not ideal or sometimes missing. My question is: Which screws are best suited for the proper and stable assembly of Ikea Metod base cabinets?
I am particularly interested in several points:
- Which types of screws (length, diameter, material) are most commonly used for joining the individual components?
- Are there any screws that work especially well with the furniture materials (particleboard, MDF)?
- Which screws are recommended for mounting the plinth and possibly for wall attachment?
I would appreciate detailed information or also tips on common mistakes when choosing screws. Thanks in advance!
TARAON
5 Jan 2022 11:50
Hello everyone!
I totally get the screw debate around Metod cabinets – nobody wants their kitchen to be unstable or the cabinet to fall apart during the next cooking attempt. 😉
To keep it short and simple: 4x50 mm (2 inches) wood screws are great, especially if they’re nicely galvanized. But honestly, if it makes you feel better, go ahead and pre-drill, even if it’s not required. Some call it paranoid, I call it smart!
For the plinth or when attaching in more delicate areas, I like to use 3.5x30 mm (1¼ inch) screws because they don’t go overboard.
Oh, and one more tip: avoid cheap screws as the threads tend to wear out quickly.
Best regards from the screw artist!
kainso
5 Jan 2022 12:17
Juan31 schrieb:
For Metod base cabinets, pre-drilling is not strictly necessary, but it’s a good option if you want to be on the safe side.
Thanks, that helps me a lot. I’ll treat pre-drilling as optional then – I’ll just do it in more critical areas.
I’m also interested in the fasteners for the hinges and drawer slides. These often require machine screws or similar – are there recommended sizes and types that Ikea typically uses or that have proven reliable?
Z
zarJody68
5 Jan 2022 13:04
The screws used for hinges and drawer slides in Ikea Metod are typically M4 machine screws with a length of about 16-20 mm (5/8–3/4 inch). They usually have a pan head or flat head and are often fastened with a hex socket (Allen) drive.
For mounting on metal fittings and the cabinet carcass, this type of screw is ideal because it offers higher strength and works well with threaded inserts.
Tip: If you are looking for replacements, make sure the screws have metric threads, not wood threads.
A typical hinge screw set often also includes matching washers to ensure better load distribution.
klo61
5 Jan 2022 13:45
I would like to expand on the point made by zarJody68:
The machine screws M4 for hinges and drawer slides are standardized, usually with a length of 16–20 mm (5/8–3/4 inch). Due to the stress from opening and closing the doors, it is important to use high-quality screws with matching washers.
Important: Screws should not be too long to avoid breaking through the threaded inserts or nuts.
For replacement parts, Ikea often offers these screws as spare parts for Metod, but metric screws of the specified dimensions are also a practical alternative available at hardware stores.
For dark-colored fronts, using black or dark zinc-plated screws can prevent visually distracting contrasts.
BARSAN
5 Jan 2022 13:56
Main screws: 4x50 mm (2 inches) wood screws.
Base: 3.5x30 mm (0.14x1.18 inches).
Hinges: M4 machine screws, 16-20 mm (0.63-0.79 inches).
Pre-drilling is optional but helps with precise placement.
Anchors depending on wall material.
Use galvanized screws.
kainso
6 Jan 2022 08:10
I’m checking in again with an update.
I have now purchased 4x50 mm (2 inch) galvanized wood screws with coarse threads and M4 machine screws, 20 mm (0.8 inch) long, as well as a set of anchors for concrete walls.
During the installation yesterday, it became clear that the 4x50 screws hold really well, and the base mounting with 3.5x30 mm (1.4 inch) screws also worked without any issues.
What I’m still not entirely satisfied with is the installation of the hinges: I used the original screws here, but despite torque limitation, I sometimes have the feeling that they “give” a bit.
Are there screws with higher strength that are more stable but still fit well into the threads of the mounting plate?
Or is this more a matter of precise installation?
