ᐅ How can I install Ikea Metod cabinets efficiently in limited space?
Created on: 4 Sep 2022 08:13
MertvinHello everyone, I am facing the challenge of installing Ikea Metod cabinets in a relatively small kitchen and using the space efficiently. The available area is limited, so standard layouts hardly fit, and I want to avoid wasting space by simply lining up the units. What strategies are there to optimize the design and use of the Metod series so that storage is maximized despite tight conditions, without making the space impractical? I am especially interested in how to best plan and combine the individual cabinet modules to allow flexibility for different room situations — also looking for ideas on special modifications or tricks to organize the available space effectively.
A precise measurement of the available space is essential, including reasonable allowances for doors and walkways. If space is limited, I recommend using corner units that optimize storage by employing either corner carousel shelves or swivel mechanisms. Pay special attention to the following points:
- Adjust the cabinet depth: For example, Metod offers depths of 37 cm (15 inches) and 60 cm (24 inches); avoid taller units like pantry cabinets if they significantly narrow the room.
- Plan with different widths: 20, 40, and 60 cm (8, 16, and 24 inches) modules provide flexibility in layout.
- Hang wall cabinets higher to keep storage space available underneath.
- Use internal drawers to improve access in tight spaces.
Additionally: Do you need storage space for larger pots or prefer many small compartments? This will greatly influence your choice of inserts.
Allow me to suggest a structured approach:
First, you should document the exact room layout — dimensions, door swings, windows, and electrical outlets. This forms the foundation.
Second, initially choose modules based on the height, width, and depth that fit your available space. For example, Metod offers base cabinets that are 80cm or 100cm (31.5 inches or 39.4 inches) high, as well as tall cabinets of 200cm or 240cm (78.7 inches or 94.5 inches) height. Especially in tight spaces, lower base cabinets or half-height cabinets are often better because they make the room feel more open.
Third, consider corner solutions with carousels or LeMans pull-outs. Although these are more expensive to purchase, they save space and improve accessibility inside the cabinet.
Fourth, think about a flexible cabinet system with adjustable shelves and pull-outs that can be customized individually.
Finally, I recommend using the Ikea kitchen planner online before buying to experiment with different layouts. This often helps you quickly identify which combinations work best in your space.
It's interesting how quickly everyone defaults to the classic corner solutions. But what if the room doesn’t even have a proper corner? Then Metod just becomes a grid of rigid modules that you can’t cleverly rearrange. I think Ikea often forces you too much into their standard dimensions. A bit more DIY or custom work would be more efficient here. Sure, it's more complicated, but ‘efficient’ doesn’t always mean ‘off the shelf.’
Tall cabinets in small spaces? For me, that’s often a mistake. They visually take up too much space and feel overwhelming.
That only helps to a certain extent if there’s nothing useful placed or hung underneath. Sometimes less is simply more.
fiman schrieb:
The most effective way to use Metod in small kitchens is by relying on tall cabinets and corner solutions.
lorena schrieb:
Hang upper cabinets higher to keep storage space below.
edisonbla4 Sep 2022 16:55Sounds like Metod is more suited for people with plenty of space – or enough patience for cutting and fitting. But you can also approach it with a bit of humor: how about using the Metod cabinets as room dividers? This way, you gain some additional surface area and storage space without overcrowding the room. I think it’s important not to overload small rooms but instead focus on the essentials and maybe cleverly use some furniture pieces for multiple purposes.
By the way, anyone who often needs to rearrange things will appreciate Ikea’s modular cabinets. You can practically take them apart and reassemble them – almost like Lego for adults!
