ᐅ How can I effectively remove scratches and stains from Ikea BESTA surfaces?
Created on: 23 Sep 2022 11:17
Ninapau
Ninapau
23 Sep 2022 11:17
I joined this forum because I urgently need advice: How can I effectively remove scratches and stains from Ikea Besta surfaces? I have a white, matte surface that has developed some small scratches and stubborn stains over time (e.g., wine or coffee stains). I want to avoid damaging or ruining the surface. It is important to me to use a gentle but effective method that can not only remove superficial dirt but also reduce these typical signs of wear. Does anyone have good tips on which household remedies or cleaning products are particularly suitable? And what is the recommended procedure? I have already tried several things but with limited success—I don’t want to try anything blindly now that might make it worse. Thanks in advance for any helpful answers!
Trate47
23 Sep 2022 14:52
Hello Ninapau,
First of all: respect for thinking things through carefully before you start cleaning – that already makes a good impression! 😄
I also have BESTA furniture at home, and I found that being very gentle is key. Scratches often remain visible, which is basically the natural aging of the surface.
For stains (especially red wine or coffee), you can try a mixture of some warm water and mild dish soap. Important: use a soft cloth, do not rub, but rather dab, and then dry thoroughly. For light scratches, some furniture finishers even offer special repair kits – these can work wonders, but usually suit wood better.
If it’s particularly stubborn, sometimes a tiny bit of toothpaste (the kind without abrasive particles!) on a damp cloth helps – gently polish and then wipe off. But be careful not to rub too hard, or the matte finish may be lost.
Otherwise, the best approach is probably to treat the furniture with a bit of care and accept signs of use as character that makes the furniture feel more alive! 😉
Good luck and don’t get discouraged!
GiRoyce
24 Sep 2022 09:03
Trate47 schrieb:
Scratches often remain visible, which is essentially the natural aging of the surface.
Exactly, that's a good point.
I would like to add that it is very important not to use harsh or abrasive cleaners on plastic- or melamine-coated surfaces like those on Ikea BESTA. This can further damage the surface. The best approach is to use lukewarm water with a mild dish soap and a soft microfiber cloth, as Trate47 already mentioned.
If stains have been absorbed by liquids, sometimes gently soaking with a cloth soaked in a mild soapy solution can help. Afterwards, dry the surface thoroughly to avoid permanent watermarks.
For small scratches, there are special polish products available that are designed, for example, for plastic furniture. You can carefully test these on an inconspicuous spot first.
I am also wondering how deep your scratches really are – are they truly penetrating or more superficial? That would influence the choice of method a bit.
In any case: never use aggressive cleaners containing solvents or alcohol; these will dissolve the coating.
Could you maybe describe which cleaning products you have tried so far? That would make the recommendations here easier.
Ninapau
24 Sep 2022 17:45
Sure, glad to. So far, I have used dish soap with warm water (although sometimes with too much pressure), also tried glass cleaner (because of the stains), and occasionally alcohol-based wet wipes, which in hindsight didn’t feel ideal.
The scratches are rather superficial, not deep gouges. It sometimes looks like a kind of dull haze in certain spots. Some of the stains have set in, as I wasn’t able to clean them quickly enough.
Thanks in advance for your advice! I just wanted to be cautious not to cause any damage, but I’m really a bit unsure about the best approach. Maybe there’s a special care product for white matte surfaces?
Looking forward to more suggestions!
Nathanaelk
25 Sep 2022 08:27
Ninapau schrieb:
Maybe there is a special care product for white matte surfaces?
A very relevant question!
White matte surfaces, like those on Ikea BESTA furniture, are usually made from melamine resin-coated particleboard. The surface is hard but not resistant to all cleaning agents. Here is my detailed recommendation for care and repair:
- Start with cleaning: Use lukewarm water with a few drops of pH-neutral dish soap and a soft microfiber cloth. Dab at stains rather than scrubbing to avoid damaging the matte finish.
- For stubborn stains (such as red wine or coffee), it is appropriate to lightly dampen the soft cloth with water diluted vinegar essence (about 5% acidity). Vinegar dissolves organic residues and is mildly acidic. Be cautious with extended contact time, so test first.
- For minor scratches, I do not recommend conventional polish products – they are often too harsh. Instead, special furniture care wax or repair pens designed for melamine surfaces can be used. Apply sparingly according to the instructions and remove any excess product. Important: always try on an inconspicuous area first.
- In general: avoid abrasive cleaners, solvents like acetone or alcohol, and do not use steel wool or similar abrasive tools.
Can you specify which types of stains you need to remove most often? And would working with a small test area be feasible? Often the type of soil determines the best cleaning method.
I’m happy to assist with further questions to help find the perfect solution.
