ᐅ How can I effectively protect Ikea BESTA furniture from moisture damage in the bathroom?
Created on: 9 Jul 2020 08:23
BADEOHello everyone,
I recently assembled some IKEA Besta furniture in my bathroom and am now wondering how to effectively protect it from moisture damage. Bathrooms tend to be quite humid, especially after long showers, and I want to prevent the furniture from swelling or mold from developing.
Specifically, I am interested in proven protective measures—whether additional sealing, special coatings, or technical adjustments during installation (e.g., spacing from the wall, ventilation). Any advice on proper maintenance or if anyone has experience with alternatives to the standard BESTA products would also be very helpful.
I look forward to tips and recommendations on how to use BESTA furniture in the bathroom as durably and damage-free as possible.
BADEO schrieb:
how I can effectively protect them from moisture damageI can understand well how stressful these kinds of problems can be, especially when you have furniture you like but are afraid of damage. I once tried to use BESTA in the bathroom myself and wasn’t sure if it was a good idea at all.
What helped me was sealing the backs and bottoms of the cabinets with moisture-resistant silicone where the furniture might come into contact with tiles or steam. I also always made sure that the furniture was not pressed directly against the wall but left a small gap to allow air circulation.
Like you, I wonder if there might be better materials or methods to protect the edges in particular.
BADEO schrieb:
Specifically, I am interested in which protective measures have proven effectiveThere are several very effective approaches I can recommend. First, it is important to understand that IKEA BESTA furniture is basically made of MDF panels, which can swell and soften very quickly when exposed to moisture. Therefore, all possible sources of moisture ingress should be minimized.
The following steps have proven effective:
- Before assembly, treat all surfaces with a water-repellent clear coat, preferably polyurethane-based and suitable for furniture.
- Pay particular attention to thoroughly coating the edges or protecting them with plastic edge profiles, as moisture often enters there.
- If the back panel is not already water-resistant, additionally seal it with an acrylic coating.
- Leave a gap of at least 1–2 cm (0.4–0.8 inches) between the furniture and the wall to allow air circulation and prevent condensation.
- In the bathroom, ensure extra air circulation, for example by regular ventilation or using an exhaust fan.
A small tip: If parts with a lot of water contact (such as under a washbasin) are installed, it is recommended to use water-resistant furniture panels (such as HPL or plastic) or at least additionally protect these areas with surface laminates.
By the way, I’d be interested to know if you place the furniture directly next to the shower or bathtub – that can significantly affect the choice of protective measures.
Thank you for the previous suggestions.
I hope that a combination of protective coating and ventilation will be sufficient, but the tip about edge protection profiles seems sensible. Are there any recommendations on whether plastic or aluminum is better? And is it easy to apply the protective coating yourself?
Franz schrieb:That sounds interesting—how exactly did you do that? Did you apply the silicone directly to the back panel and then onto the tiles? Or was it more of a continuous seal around the edges?
PLOMA schrieb:Basically close to the sink and shower area, but not right next to or underneath a direct water spray. The bathroom is medium-sized, with a window that provides ventilation, but I’m preparing for daily use when moisture is common.
I’m curious whether you place the furniture directly next to the shower or bathtub
