ᐅ How can I modify IKEA BESTA into an open shelving unit with lighting and storage?
Created on: 11 Sep 2024 14:23
Ben-ja
Hello everyone, I am currently planning to modify my IKEA Besta shelving unit and have a question: How can I convert the Besta into an open shelf with integrated lighting and additional storage without compromising stability or aesthetics? It is important to me that the lighting is discreet yet functional, preferably LED-based, and fits well with the existing design. I also want to make good use of the opportunity to expand the storage space, for example with extra compartments or drawers that blend in harmoniously. Who has experience with such modifications and can offer advice on material selection, necessary tools, or special techniques?
lyndon
12 Sep 2024 11:45
Ben-ja schrieb:
Regarding the electrical supply, I have a special requirement: I want to install the lighting as discreetly as possible on the side profiles or inside the shelves without visible cables.
This is quite feasible if you run the cables within the channels of the Besta side panels or behind the back panels. Use thin cables and secure them with small clips that can be placed inconspicuously. Drilling should be done sparingly, ideally in spots that will later be covered by decor or shelves. Motion sensors work well, but make sure they are compact enough and have enough space. There are also versions that can be integrated directly into the LED strips.
koduga
12 Sep 2024 13:22
I really like your idea, especially the combination of an open shelf and lighting. Using motion sensors can add a lot of convenience. However, when routing the cables, I would be cautious and keep in mind that not every deviation from the original plan is beneficial—sometimes less is more. Still, if you’re unsure, it can help to loosely assemble everything first and test it. It’s better to check if everything fits before drilling than to be frustrated later.
Marcellela
12 Sep 2024 14:03
I like to use self-adhesive cable ducts for this kind of thing, which can be discreetly installed inside the sides. Motion sensors for LED strips are also very useful, but they are not compatible with all types, so always check compatibility before purchasing.
Ben-ja
13 Sep 2024 09:58
lyndon schrieb:
Motion sensors work, but make sure they are small enough and have enough space. There are also versions that you can integrate directly into the LED strips.
Thanks for the tip, I didn’t know about the integrated motion sensors! Does anyone know if their brightness can be adjusted, or if they just switch on and off? And what about the color temperature of the LEDs? I’d like a warm white light that isn’t too harsh but still makes the items on the shelves clearly visible.
juMira46
13 Sep 2024 11:30
Ben-ja schrieb:
Does anyone know if these can be dimmed or are they just simple on/off?
It depends on the motion sensor and the type of LED used. There are integrated solutions that are dimmable, but these are usually more expensive. For your shelf, a warm white LED with about 2700–3000 Kelvin (about 4900–5400 degrees Fahrenheit) would be ideal – it creates a cozy atmosphere without being too harsh. Motion sensors are generally on/off, but you can adjust brightness with an additional dimmer or smart controller. This way, your open shelf stays stylish even when lit.
