ᐅ How can I install LED lighting in BILLY shelves without any issues?
Created on: 3 Feb 2023 09:17
sin_lau
Hello everyone, I want to install LED lighting in my Billy shelves but have some concerns regarding installation and potential issues. Specifically, I am interested in how to best mount LED strips or LED light bars without visible cables or difficulties with the power supply. I also want to avoid damaging the shelves during installation or having the LEDs malfunction later due to excessive heat or insufficient power source. Who has experience with this and can provide a step-by-step explanation on how to install LED lighting in Billy shelves smoothly? Maybe also some tips on recommended products, suitable connection methods, and possible pitfalls. Thanks in advance!
Lilau
3 Feb 2023 12:07
I can easily understand that this might seem intimidating at first, especially if you don’t often work with electricity and electronics. 🙂
If you’re unsure and worry it might be too complicated, try taking small steps and set up the shelf with lighting temporarily at first.
If you like, we can also go through individual steps together here—that always helps me when I encounter something new.
Nofege
3 Feb 2023 12:56
Here is a brief guide for LED lighting in Billy shelves:
1. Material selection: 12V LED strips, preferably dimmable and with adhesive backing.
2. Measuring: Measure the length of the shelves and cut the LED strips to size (pay attention to the cut points).
3. Clean the surface: Remove dust and grease to ensure good adhesion of the tape.
4. Stick the strips in place and attach the cables to the shelf frame using cable clips.
5. Position the power supply, ideally on the bottom shelf with ventilation.
6. Check connections: Observe polarity and measure voltage with a multimeter for safety.
Common mistakes:
- Reversed polarity
- Strips too long without proper cutting
- Insufficient ventilation for the power supply
- Unsafe cable routing
I hope this helps.
cassandra
3 Feb 2023 13:34
RETRAVIS schrieb:
Heat generation is generally not a concern
Correct, the LEDs and power supplies only produce minimal heat.
Additionally, when choosing the power supply, you should consider the appropriate capacity by adding up the total wattage of the LED strips and using a power supply with about 20% headroom.
I also recommend using connectors with good contact quality to avoid loose connections.
karlau
3 Feb 2023 14:03
labar43 schrieb:
Dare to wire it yourself – you can do it
Sure, but that’s exactly the point: most people overestimate how difficult it is. I always find it amusing how a simple DIY project gets turned into a high-end task here.
If you don’t get distracted by all the “instructions,” you can finish it in 30 minutes and that’s it.
labar43
3 Feb 2023 14:43
karlau schrieb:
a simple DIY project turned into a high-end deal here
I think it’s great when everyone can find their own way! 🙂
For beginners, tips like these are important so they overcome their fear of wiring and end up proud of their finished result. That’s why it’s fantastic when different perspectives come together here!
Lilau
4 Feb 2023 08:22
A quick question for everyone: How did you route the cables through the shelf without making them visible? Did you use special cable channels or simply hide the cables behind the back panels?
I'm still quite confused about this and find it challenging to keep the cable clutter looking neat.
