ᐅ How can I connect open and closed sections in Ikea Besta storage units?
Created on: 22 Jul 2023 10:42
Joliben
Hello everyone, I am currently planning my new Ikea Besta storage solution and facing the challenge of harmoniously combining open and closed sections. My specific question is: How can I effectively and visually appeal connect open elements like shelves or display cabinets with closed elements such as drawers or doors in Ikea Besta storage units? I am interested in practical tips regarding assembly and stability, as well as design ideas to ensure a coherent overall look and optimal use of the storage space. Does anyone have experience with modular extensions, connection techniques, or special accessories that can help facilitate this transition? I appreciate any advice!
usbla schrieb:
The material properties as well as the weight of the contents should also be considered to ensure long-term stability.Absolutely correct, this is one of the main factors. Additionally, I recommend installing cross braces or backsheets on open shelves, even if the maximum load is low. These significantly improve the torsional stiffness.
GiRoyce schrieb:
Maybe one more tip: Plan in advance for the load on the open shelves.Exactly, especially if you plan to store heavy (electronic) devices or books.
Have you already checked whether your floor is completely level? Small unevenness often causes rocking or small gaps in modular systems like Besta. Adjustable furniture feet are really valuable in such cases.
As an addition: When connecting open and closed Besta elements, it is often helpful to work with shelves combined with cover panels. These cover panels can conceal gaps and visually smooth the transitions.
Step-by-step, I would recommend:
- Measuring the individual modules, including the gap widths
- Choosing connectors suitable for the weight and usage profile
- Integrating back panels, both in open and closed shelves, to increase stability
- Using cover strips or color-matched panels for a clean appearance
Also, using the correct screw length and tightening the connections again after one day of settling helps to avoid deformation.
