ᐅ How can I connect open and closed sections in Ikea Besta storage units?
Created on: 22 Jul 2023 10:42
Joliben
Joliben
22 Jul 2023 10:42
Hello everyone, I am currently planning my new Ikea Besta storage solution and facing the challenge of harmoniously combining open and closed sections. My specific question is: How can I effectively and visually appeal connect open elements like shelves or display cabinets with closed elements such as drawers or doors in Ikea Besta storage units? I am interested in practical tips regarding assembly and stability, as well as design ideas to ensure a coherent overall look and optimal use of the storage space. Does anyone have experience with modular extensions, connection techniques, or special accessories that can help facilitate this transition? I appreciate any advice!
GOLO42
22 Jul 2023 11:07
Your question about connecting open and closed sections with Ikea Besta is very well posed – the topic involves both functional and aesthetic aspects that should not be underestimated. Basically, I recommend first carefully checking the structural conditions, as the combination of open shelves and closed cabinets brings different load distributions and stability requirements.
- Assembly: When assembling, it is advisable to securely fix the individual modules with the supplied connectors, but especially to use cross braces or wall mounts to prevent tipping effects in open shelves.
- Appearance: For a harmonious overall look, it helps to keep the color and material scheme consistent. Variations in white or with wood accents can be combined well.
- Connection techniques: Ikea offers special connection rails, such as the "Besta connecting bracket," which allow you to mount modules firmly side by side or stacked vertically. These also help to make small gaps between the elements invisible.
An important point is the order of assembly: I recommend mounting the closed sections first and then adjusting the open shelves so that no visible screws or connectors are distracting.
To assist you better: What sizes and depths of modules are you planning? Will the shelves be placed against a wall or used as a room divider?
JORGERON
22 Jul 2023 11:33
Open and closed areas at Besta are best connected using the original connecting rails. Regular wall fixings increase stability. Make sure to choose the same heights and depths for a clean overall appearance.
GiRoyce
22 Jul 2023 12:04
Hello! I can definitely relate to your question, as I recently completed the same project using Ikea Besta. What helped me was not simply placing the open and closed units side by side, but working with connecting elements—such as a narrow top panel or a thin shelf—that visually link them together.
Also, proper lighting in open areas is crucial to make items not only easy to find but also attractive to display. For closed sections, I really appreciate using drawer inserts and dividers to keep things practical and organized.
One more tip: plan ahead for the load capacity of the open shelves. I added sturdy materials or extra back panels because the thin side panels of Besta can otherwise seem a bit unstable.
Have you already decided on a specific color option?
loken
22 Jul 2023 13:16
Ikea Besta really makes an impression when you cleverly combine open and closed units! 😎 I connected my hybrid of open shelves and closed boxes with a continuous cover panel – this creates a clean look and adds extra stability.
The most important thing is: Use the open compartments to showcase decorations or books, while the closed sections are perfect for hiding clutter.
As a small tip: Cable clips or discreet cable channels work great if you want to integrate lighting. This keeps everything neat and easy to maintain. Have fun building!
U
usbla
22 Jul 2023 14:02
For the structural combination of open and closed Ikea Besta units, I recommend the following:
- Use the original connecting fittings for maximum stability.
- Consider the maximum load capacity of open shelves (up to about 25 kg (55 lbs) per compartment) and closed units (usually higher).
- Install wall brackets to secure the units to the wall and prevent tipping.
- Keep module heights consistent to ensure seamless transitions.
- Use cover panels and shelves as visual and physical connecting elements.
The material properties and the weight of the contents should also be taken into account to ensure long-term stability.
