ᐅ How can I clean matte IKEA Metod cabinet fronts without causing yellowing?
Created on: 7 Jun 2020 09:38
Rajuba
Rajuba
7 Jun 2020 09:38
Hello everyone, I have matte fronts from the IKEA Metod kitchen, which I really like visually, but I have the problem that they quickly yellow or get stained when cleaning. My question is: How can I clean matte IKEA Metod fronts effectively and gently without causing the surface to yellow or leave unattractive residues? So far, I have only used mild dish soap with water, but this doesn’t seem sufficient, or the color changes slightly. Are there any special cleaning products or methods recommended to keep the fronts clean and colorfast? I would also like to know if aggressive cleaners or even abrasive agents can cause problems here. I would be very grateful for tips and experiences!
floga
7 Jun 2020 11:13
Rajuba schrieb:
How can I effectively and gently clean matte IKEA Metod fronts without causing the surface to yellow or develop unsightly residues?
I know that all too well, as I also struggled with yellowing on my METOD fronts. I want to emphasize that after some time, I wasn’t sure whether my cleaning products were making the problem worse or if the material is generally sensitive.
What worked well for me was cleaning with lukewarm water and a drop of pH-neutral soap. It’s important not to use any harsh or abrasive substances—even microfiber cloths pressed too hard slightly roughened the delicate matte surface in my experience. I also made sure to always wipe the fronts with a clean, dry cloth afterward to avoid dust and moisture.
I’ve also heard some people recommend vinegar or alcohol-based cleaners, but those damaged my surface and likely contributed to yellowing or at least changed the appearance.
If you have already tried special cleaners, it would be interesting to know which ones.
Genevieve
7 Jun 2020 14:47
floga schrieb:
I also know that some people recommend vinegar or denatured alcohol, but that damaged the surface for me
That’s true, and from my perspective, the issue is a bit more complex than it is often presented. First, you need to understand what material the matte surface is made of – it is often a coated particleboard or MDF with an acrylic or melamine finish. These layers react quite differently from a chemical standpoint to cleaning agents.
I generally agree with the recommendation to use lukewarm water and a mild, pH-neutral cleaner, but I think it’s important to be more precise about the cleaning frequency and the concentration of the cleaning solution. Especially with matte surfaces, soap residues tend to leave unattractive films, which can cause fronts to appear duller or even yellowed.
Additionally, I would consider simply wiping the fronts regularly with a damp cloth and only using a specialized plastic cleaner that is explicitly suitable for matte surfaces when necessary.
My question to Rajuba would also be: How long have your fronts been in use? Does the surface change more because of environmental factors or perhaps sunlight exposure? This can also play a role when it comes to yellowing.
Ernesto
8 Jun 2020 08:51
Genevieve schrieb:
You first need to understand what material the matte surface is made of
Very good point, as there are different types of IKEA METOD fronts:
- Matte lacquered MDF fronts with acrylic or polyurethane coatings
- Melamine resin-coated chipboard
Both are sensitive to incorrect cleaning products and mechanical stress.
For optimal cleaning, I would recommend the following procedure to minimize the risk of yellowing and surface damage:
- Use only lukewarm water and a mild, pH-neutral detergent with as little or no added fragrance or colorants as possible.
- Use soft microfiber cloths that are “lint-free” and slightly damp, avoiding excess moisture on the surface.
- Press the cloth gently; avoid rubbing hard to protect the lacquer layer.
- Always wipe the fronts dry afterward with a dry, lint-free cloth.
Avoid:
- Abrasive cleaners, as they damage the smooth surface and cause uneven glossy spots on the matte finish
- Alcohol-based cleaners such as spirits, which can attack the coatings and promote yellowing
- Vinegar-based cleaners, which can also damage the protective layer
- Prolonged direct sunlight exposure on the fronts (can trigger chemical reactions)
Also interesting: Some users report that occasional cleaning with a mild plastic care oil (used very sparingly!) helps maintain the matte effect and reduces yellowing. However, this requires a delicate touch and should first be tested in an inconspicuous area.
One question: How often do you clean the surfaces? Daily, weekly? And which products have you been using exactly?
