ᐅ How can I clean Ikea Besta furniture without leaving water spots?
Created on: 17 Jul 2020 08:23
taniel
taniel
17 Jul 2020 08:23
I recently purchased some Ikea Besta furniture and am now looking for the best cleaning method to prevent water spots from forming on the surface. My furniture has both high-gloss and matte finishes, and even with quick wiping, water alone still leaves unsightly marks that are very difficult to remove.
I am especially interested in which cleaners or homemade mixtures can help prevent these water spots. It would also be helpful if anyone could share tips on the best way to dry the furniture after cleaning to avoid such marks.
Are there any recommendations regarding the choice of cleaning cloth or wiping technique?
Thanks in advance for your suggestions and experiences!
JAMESONB41
17 Jul 2020 08:45
It is best to use a microfiber cloth for cleaning and then immediately wipe with a dry cloth afterwards.
Avoid cleaning the furniture with a too wet cloth, as this can cause water stains.
LANICOLE
17 Jul 2020 09:30
taniel schrieb:
I’m particularly interested in which cleaners or mixtures of household remedies I can use to prevent these water stains.
Hello taniel,
I can suggest a simple method that works well for many Ikea Besta owners:
- First: Never clean with a fully wet cloth. The cloth should be only slightly dampened, then wipe the furniture.
- A mild dish soap and water mixture works well for cleaning (1–2 drops of dish soap per about 1 liter (1 quart) of lukewarm water).
- After wiping with the damp cloth, always follow up by polishing with a dry, clean microfiber cloth.
- Water stains often result from mineral deposits in the water. Therefore, boiled or filtered water usually works better.
taniel schrieb:
Also, it would be helpful if someone could give tips on the best way to dry the furniture after cleaning in general.
I recommend drying immediately, preferably with an absorbent, lint-free cloth that fully removes any water film.
Rough cloths or paper towels are less suitable as they may leave lint behind.
Finally, I advise against drying furniture in direct sunlight, as this can cause staining.
I hope this helps you!
noge58
17 Jul 2020 10:14
Great topic, I also keep struggling with water spots on my Besta shelves!
I’ve had very good results using distilled water. Whenever I used regular tap water, those ugly spots appeared after a while :/
Try the following:
- Clean with a slightly damp microfiber cloth, using only distilled water (no cleaning agents!)
- Immediately dry afterwards
This works really well for me! Give it a try—you’ll be impressed!
Scarlett
17 Jul 2020 11:02
I can fully understand how frustrating this can be, especially when you put in effort and still end up with water stains.
What helped me was simply being a bit patient during the drying process and avoiding rubbing too hard, as that can damage the material.
JAMESONB41 schrieb:
It’s best to use a microfiber cloth for cleaning and immediately follow up by wiping with a dry cloth.
I also think that’s important – but so is the size of the cloth and the way you move it. It’s better to use small, gentle motions and turn the cloth frequently.
Maybe this will reassure you – it happens to all of us sometimes, and you’re doing it right!
Nadine
18 Jul 2020 08:10
Hello taniel,
I would like to add some basic tips that are often overlooked:
- The water used should be low in calcium to prevent water spots.
- Used cloths should always be clean and lint-free to avoid leaving residues.
- Avoid aggressive or alkaline cleaners, as they can damage the surface and make stains more likely.
Also:
After cleaning, you can buff the surface with a soft, dry cloth. This helps remove moisture and gives a nice shine.
If spots do appear, sometimes a drop of rubbing alcohol on the cloth can help, but be sure to test it first on an inconspicuous area.
I hope these tips help you get rid of water spots for good!
