Hello everyone, I recently purchased an IKEA Platsa system and am unsure about the best way to care for the doors and drawers in order to preserve the surface long-term and prevent damage such as scratches or discoloration.
Specifically, I am interested in the following points:
- Which cleaning products are suitable and which should I definitely avoid?
- What is the best way to deal with grease or dust buildup?
- Are there any special care tips for the metal hinges and sliding tracks?
- At what point does regular maintenance of the mechanisms become worthwhile?
I want to proceed as thoroughly as possible while being gentle, and I would appreciate any concrete experiences or recommendations.
PeoDaniel23 May 2023 10:12Hello Ruhau,
Regarding your question about caring for IKEA PLATSA doors and drawers, I can share a few tips that I have been using for years:
- Cleaning agents: It’s best to use mild, non-abrasive cleaners such as pH-neutral all-purpose cleaners or gentle soap solutions. Avoid harsh cleaners containing ammonia, alcohol, or bleach, as these can damage the surface.
- Dust and grease: For dust, a soft microfiber cloth usually suffices. For grease stains, use slightly warm water with a bit of dish soap, but be careful not to get the surfaces too wet to avoid water damage on the edges.
- Hardware: You can occasionally lubricate the metal hinges and sliding tracks with a drop of silicone oil or a special furniture lubricant. This helps ensure quiet and smooth operation. However, don’t use too much, as it can attract dirt.
- Maintenance: I recommend checking the hardware every six months to ensure proper function and adjust if necessary. Screws often loosen or dust accumulates in the sliding tracks, which should then be cleaned out.
I hope this helps! Feel free to ask if you have any more questions.
Hello Ruhau,
I would like to respond with a brief overview that hopefully provides you with a clear maintenance routine for PLATSA doors and drawers:
1. Surface Cleaning:
- Use a soft cloth and lukewarm water with a small amount of dish soap for daily cleaning.
- For stubborn stains, a mild acrylic-based cleaner can be used, as many PLATSA surfaces are melamine-coated.
- Never use abrasive cleaners or scrubbing pads, as they will permanently damage the surface.
2. Mechanical Parts:
- Regularly clean hinges, runners, and guide rails with a dry brush or compressed air to remove dust and dirt.
- Avoid using oil on powder-coated parts, as oil attracts dust and causes buildup.
- Instead, I achieve good results with a light application of dry PTFE spray or silicone spray.
3. Preventive Maintenance:
- Check all screws every 3 to 6 months and tighten them if necessary.
- Pay attention to noises or stiff movements when opening or closing to detect early signs of wear.
4. General Tip:
- Avoid direct sunlight exposure, as UV rays can cause discoloration.
- Avoid moisture and do not place wet objects on the surfaces.
I also want to add: many people underestimate the care of the runners. If they are dirty, drawers often stick, leading to premature wear. I recommend installing protective felt pads on the front edge if they are not already in place.
Overall, gentle, regular cleaning combined with occasional maintenance is enough to keep your PLATSA looking great for a long time.
4. General Tip:
Nofege schrieb:
Avoid using oil on powder coatings, as oil causes dust to stick.That's a good tip.
For the hinges, it’s better to use dry silicone spray and clean them regularly with a brush.
When cleaning the doors and drawers, warm water and a soft cloth are completely sufficient.
