ᐅ How can I build IKEA Metod kitchen cabinets to be sturdy and child-friendly?
Created on: 16 Nov 2024 08:27
sosusanne
sosusanne
16 Nov 2024 08:27
Hello everyone!
I’m about to start assembling my Ikea Metod kitchen, but I want not only sturdy furniture but also to make it as child-friendly as possible. Since my little ones often play or help out in the kitchen, safety and durability are especially important to me.
I’m interested in hearing which steps and materials you use to build the Metod kitchen units as solidly as possible. Do you have any tips on making the furniture child-safe, such as rounding sharp corners, securing everything properly, and ensuring the units can withstand small carts or rough play?
I’m looking forward to practical experiences, specific product recommendations, or safety measures that have proven effective in daily use. It would also be interesting to know if certain modules or accessories from Ikea work particularly well or can be modified for this purpose.
Thanks in advance for your advice!
Jensson
16 Nov 2024 10:11
Hello sosusanne,
First of all, you have a very clearly stated concern, which makes it easy to address.
Regarding the stability of Metod kitchen cabinets:
- Always use all supplied dowels and screws. Ikea components are often designed to rely on individual connections, so avoid any “cost-saving” shortcuts when securing them.
- Additionally, I recommend fastening the base cabinets to the wall. Metod offers special brackets that you can screw behind the cabinets to the wall. This significantly increases stability and prevents tipping.
- For base cabinets, also ensure a level surface by adjusting the feet.
Child safety:
- Rounded edge protectors (available at hardware stores) on sharp corners are invaluable.
- Hinge guards on doors prevent pinching – there are special child safety devices that can be easily installed here.
- For drawers, self-closing mechanisms are recommended to better protect children’s fingers.
Additional: When choosing cabinet fronts, opt for durable surfaces, since children often play with their hands and toys on furniture. Melamine-coated surfaces are easier to maintain in this respect.
In summary: build solidly, securely fix furniture to the wall, protect corners, and install child safety features. If you like, I can also provide a list of recommended products and installation tips.
warrenka57
16 Nov 2024 12:03
Hi sosusanne,
I know the feeling—especially with small children running around, you just want everything to be safe and stable. With my Metod kitchen, I honestly noticed right from the start that you can’t just put everything together as is from Ikea without some adjustments.
Jensson schrieb:
- I also recommend fastening the base cabinets to the wall separately.
That’s a really good point—I had to retrofit that because the whole unit felt a bit wobbly. It just gives you a much more secure feeling.
I also added special corner protection profiles that are normally used for playgrounds. They are soft, flexible, and protect children from injuries in case they accidentally slide along the kitchen corners.
Could you maybe specify which modules you plan to use? For example, in areas where there is a lot of climbing, I chose tall cabinets that are naturally more stable than base cabinets with legs.
sosusanne
16 Nov 2024 13:47
warrenka57 schrieb:
Could you please specify which modules you plan to use?
Good idea, so far my plan includes:
- two base cabinets measuring 60cm x 60cm (24 inches x 24 inches) for the cooktop and sink
- one 80cm (31.5 inches) wide base cabinet with drawers
- several wall cabinets, including a tall one for the oven with a range hood above
My main focus is on the base cabinets, as they are likely to be the most heavily used by the kids.
Do you think the tall cabinets are generally more suitable where children play, due to their stability?
And regarding corner protection profiles, do you have any product recommendations? So far I’ve only seen options with foam padding, but they don’t seem very high quality.
Palenar
17 Nov 2024 08:55
Hello sosusanne,
I have been working on the topic of Metod kitchen assembly for some time and have tried various approaches with the goal of stability and child safety. The crucial point, which you will probably want to consider as well, is the connection between the individual modules and how they are secured.
Important:
- Always use continuous carcass connections, meaning metal fasteners (Confirmat screws) that provide good strength. Do not skip these, even if the factory-preassembled snap-fit seems sufficient.
- Attach the units to the wall not only at the top but also at the bottom, for example with brackets mounted on the back of the base cabinets – this prevents tipping even under load.
- Additionally, use the complete set of floor protection pads from IKEA; they improve load distribution on the floor and enhance stability.
For child-friendly design:
- I recommend special PVC edge protectors, which you can find at some building and furniture hardware suppliers. They are much more durable than cheap foam protectors and can absorb minor impacts well.
- Using recessed handles instead of protruding handles can also help reduce the risk of catching or injuries.
Another tip: Small children often push on cabinet doors, so a soft-closing system (e.g., clips from Blum) ensures that doors do not slam shut suddenly.
A question for you: What type of flooring do you have? Is it very smooth? That also affects the stability of the kickboards and thus the safety during play.
Davidleo
17 Nov 2024 10:36
Palenar schrieb:
- Attach the wall fasteners not only at the top but also at the bottom
Great tip!
I would like to add that using an extra sealing or cushioning foam between the cabinet and the wall can work wonders to prevent wobbling. Additionally, my family uses non-slip felt pads under the feet of the kitchen furniture; these also protect the floor and prevent the furniture from sliding—especially important when children are around!
Regarding child safety: I’ve had a lot of success with transparent plastic cabinet locks installed inside the doors, which stop toddlers from easily opening the cabinets. This keeps the contents protected and the furniture stable.
I’m really impressed by how much can be achieved with these small tricks!
