ᐅ How can I build Ikea Metod cabinets with plenty of storage space in small kitchens?
Created on: 3 Jan 2019 18:17
Ja_mi
Hello everyone, I am currently facing the challenge of maximizing storage capacity in my small kitchen with limited space. Specifically, I am working on installing Ikea Metod cabinets. Maybe you have some experience or tips on how to best configure the Metod series to gain as much storage as possible in a tight area? I am especially interested in how to combine the cabinets effectively, whether there are smart organization options for the internal drawers, and if there are any special tricks to keep in mind during assembly or planning. I look forward to hearing your experiences and practical recommendations!
Ja_mi
4 Jan 2019 12:27
Thank you for the advice so far! One more question: How do you handle connecting individual cabinets, especially when the kitchen has unusual dimensions? Are there proven techniques to align the modules precisely and create a clean transition? I'm also interested in tips on clamps or tools that make assembly easier – does anyone have practical recommendations?
Tommy38
4 Jan 2019 14:03
Ja_mi schrieb:
How do you handle connecting the individual cabinets, especially when the kitchen has unusual dimensions?
The Metod cabinets are connected using special connector screws included by Ikea. It is important to align the cabinets so that the front edges are perfectly flush. Clamps are useful to hold the units steady while tightening and to prevent slipping.
Precise measurements are especially important for small kitchens. A spirit level and a tape measure are essential. For unusual dimensions, you can also use filler panels or side panels to visually close gaps. For offsets, it’s advisable to use wooden strips on the inside to compensate for unevenness.
As for tools: a cordless drill with adjustable torque, clamps, a spirit level, possibly a small hammer, and angles are helpful. The Ikea assembly instructions are very detailed, but a few personal tips can be especially useful in tricky corners.
rekijan
4 Jan 2019 15:56
Hello Ja_mi!
Regarding small kitchens and Metod: I once experimented with a kitchen on 5 m² (54 ft²). It’s important to approach the planning with a bit of humor. 😄 Make sure not only to arrange the cabinets perfectly but also to create order inside with clever organization.
My tip: Flexible inserts, for example for cutlery or spices, can be a lifesaver. Also, open wall units often feel lighter than fully closed ones, but of course, that’s a matter of personal taste.
And a little fun tip: Sometimes it looks better if you treat a panel as a “design statement” rather than just a last resort. This way, everything blends a bit more and the kitchen appears larger 😉.
pinJustin
4 Jan 2019 17:42
Make use of corners with carousel or LeMans cabinets. Tall cabinets for pantry storage, equipped with pull-out shelves inside. If the height is limited, it is better to reduce the depth instead, which improves accessibility.
Ja_mi
5 Jan 2019 10:18
Thank you for the valuable tips on tools and aligning the cabinets! One point I’m still unclear about: When installing tall cabinets, how do I handle stability and safety? Especially in small kitchens, where there is usually less space for anchors, I’m a bit concerned about whether stabilizing the tall units is straightforward. Is there a recommended approach to ensure a secure and wobble-free installation?
Gino38
5 Jan 2019 11:44
Ja_mi schrieb:
Is there a recommended procedure to securely install this and ensure it is stable?
Yes, tall cabinets must be securely anchored to the wall. Ikea provides various mounting hardware which should be installed according to the type of wall. Use screws and anchors that are appropriate for the wall material.
Before the final installation, also check if the floor is level and, if necessary, compensate using adjustable feet.
The connection between the modules with connector screws also contributes to the overall stability. This creates a solid construction that stands stable and secure—even in small, confined kitchens.
