ᐅ How do I build Ikea Metod cabinets for barrier-free access?
Created on: 26 Jul 2015 08:24
Rudupo
Rudupo
26 Jul 2015 08:24
I am planning to install Ikea Metod cabinets in a way that allows for barrier-free access. Specifically, I want to design the cabinets so they are suitable for people with limited mobility, such as wheelchair users. I am considering lower mounting heights, easy-to-open fronts, and maximizing storage space within reachable heights.
My question is: What special modifications are necessary when assembling Metod cabinets to achieve this? Are there particular solutions or accessories you would recommend? Also, how can I choose rails or handles that are as easy to operate as possible?
I look forward to your experiences and tips and am also interested in practical examples. Thanks in advance!
SINTAR
26 Jul 2015 09:13
for barrier-free access, I would first recommend installing the cabinets at a lower height—maximum 120 cm (47 inches). Then, be sure to choose handles that do not require twisting or pinching motions, such as bar handles. Internal drawers with full extension also make access easier. Soft-close door dampers are helpful to prevent slamming.
matthewon
26 Jul 2015 09:49
SINTAR schrieb:
For barrier-free access, I would first install the cabinets lower – max. 120 cm (47 inches) height.
That makes me wonder: Isn’t it often more practical to install cabinets higher as well, to make access easier for wheelchair users with good arm reach? Why always standardize?
Also, do you consider using cabinets that are fully wheelchair-accessible underneath? This is often overlooked but very important. Ikea Metod offers few ready-made solutions here, so please be creative!
Rudupo
26 Jul 2015 10:17
matthewon schrieb:
Also, have you considered using cabinets that are fully wheelchair accessible underneath?
That’s a very good point, thank you! I haven’t yet looked closely into whether the Metod modules can be designed to be fully wheelchair accessible due to their structure. Do any of you have ideas on how to modify panels or plinths (kickboards / baseboards) to allow space for wheelchairs without compromising stability?
And what about using special mechanisms? For example, electric openers or soft-close systems that generally make handling easier?
tutan
26 Jul 2015 11:38
Rudupo schrieb:
Do you have any ideas on how to modify panels or baseboards to provide wheelchair access without compromising stability?
Hey, that’s definitely possible! Simply reduce the baseboard height or even remove sections entirely. Using sturdy steel brackets fixed to the bottom of the Metod cabinets helps a lot. And don’t worry – this slight modification doesn’t make the cabinet unstable.
A little tip: attaching a rubber furniture strip underneath protects the floor and reduces slipping. It also makes the space feel more homely, without an industrial look 😉
Soft-close systems are great, especially if you have limited hand strength. I swear by them on all my cabinets!
glamo8
27 Jul 2015 07:52
Reduce the plinth height to create more legroom – that's exactly what I did in my case. Just make sure the cabinet still stands level. Adjusting the feet often helps; Ikea offers adjustable feet that work well for leveling.
