ᐅ How can I build an IKEA Metod kitchen with ample countertop space?
Created on: 7 Mar 2020 08:23
Kellin36Hello everyone, I am planning to build an Ikea Metod kitchen myself, with a particular focus on having a very generous work surface. My kitchen is about 3.5 meters wide (11.5 feet), and I want to create as much space as possible for preparation and working, without neglecting the storage functionality of the Metod units.
I’m especially interested in how to best arrange the cabinets and countertops to achieve this spacious surface—particularly in a rather square-shaped kitchen. Are there practical tips regarding the combination of different cabinet sizes or possibly the use of Ikea-specific extensions like corner cabinets, deeper countertops, or table solutions?
Also, I am wondering if there are any special considerations during installation when aiming to significantly extend the countertop, for example with overhangs or freestanding cooking and preparation islands connected to the Metod system.
I am grateful for any advice, experiences, or suggestions that can help me successfully combine functionality with a large work surface in practice.
Really interesting topic, Kellin36! The Metod system is indeed very flexible, and once you learn a few tricks, you can gain a lot of countertop space 😀
I remodeled our Metod kitchen myself two years ago and can already tell you: corner cabinets with carousel doors look great but unfortunately take up a lot of space in the corner – in such cases, a deeper countertop is often more practical to create additional workspace. Feel free to go for 70cm (28 inches) depth on the main work surface; it really makes a big difference!
I also built a small freestanding island that is flush with the main countertop – this makes the space feel much more open. Just make sure to use sturdy fixings so the countertop doesn’t wobble.
Don’t worry about overhangs: if you have a 20–30cm (8–12 inches) overhang, simply add matching sturdy panels underneath or edge protection, and it will be solid. Good luck with your planning – don’t get discouraged, it will turn out great!
Kellin36, my recommendation is to maximize the countertop space using fixed modules and smart planning without compromising functionality or stability.
- It’s best to choose base cabinets with a depth of 60 cm (24 inches) and complement them with deeper countertops (e.g., 70 cm (28 inches)) to provide more space toward the front.
- Corner solutions: Instead of carousel or revolving cabinets, alternative corner shelves or empty space are often advisable to allow a generous angle in the countertop.
- For islands or connecting modules, you should definitely use a continuous and stable countertop or join two countertops with sturdy connectors to prevent bending.
I’m not in favor of overly wide overhangs without proper support, as countertops from IKEA have limited load capacity depending on the material and can otherwise warp.
Also, check if you want two or more working heights, which makes flexible planning worthwhile.
noge58 schrieb:
Just make sure the mounting is secure so the board doesn’t wobble.Sure, that’s important – but honestly, many people greatly overestimate the stability of these constructions. If you really want large surface areas, you should consider not using an Ikea countertop at all, but rather a different material that is better suited for longer spans.
julian36 schrieb:
I don’t support overly wide overhangs without proper supportsI dare say most people here in the forum do exactly that – and if you rely too much on the countertops, you really need to be careful. The smooth Ikea solutions are great, but they have their limits.
My advice: it’s better to plan minimalistically and invest in nice, large surfaces using more expensive countertops – or go for a countertop split into two parts connected by a frame. Simply having more surface area doesn’t automatically mean better quality or durability.
I think it’s great that you’re putting so much thought into this, Kellin36 – large kitchen projects can quickly feel overwhelming. Your idea to combine generous work surfaces with storage functions is exactly the kind of challenge many of us face.
What helped me was the idea that the kitchen doesn’t have to be a fixed, rigid space: use multifunctional modules that can also serve as an island or extra surface. The Metod components are quite flexible in this regard, but get used to the fact that some small compromises will be necessary.
If you’re uncertain about installation: many in the community share both enthusiasm and challenges. Not every panel fits perfectly on the first try, and stability is an ongoing process. Don’t be discouraged and seek advice early if anything is unclear.
Kellin36,
for generous work surfaces in an Ikea Metod kitchen, the general rule is to use countertops that are 186 cm (73 inches) long and 68 to 70 cm (27 to 28 inches) deep. Combine these with cabinets that are 60 cm (24 inches) deep and use the shallowest possible side panels to maximize the usable surface area without interruptions.
- Corner cabinets reduce workspace, so it’s better to allow for open corners or gaps to accommodate larger countertops.
- Use metal brackets and sturdy connectors for overhangs to prevent warping.
- A freestanding island should be supported with carriers or a stable substructure.
Technically, Metod cabinets are modular, but with large surfaces, you need to ensure the countertop does not sag too much—beams or reinforcements help here.
It’s best to create your floor plan in an IKEA planner and carefully check the measurements of the countertops along with the cabinets.
