ᐅ How can I build an IKEA Metod kitchen with ample countertop space?
Created on: 7 Mar 2020 08:23
Kellin36
Hello everyone, I am planning to build an Ikea Metod kitchen myself, with a particular focus on having a very generous work surface. My kitchen is about 3.5 meters wide (11.5 feet), and I want to create as much space as possible for preparation and working, without neglecting the storage functionality of the Metod units.
I’m especially interested in how to best arrange the cabinets and countertops to achieve this spacious surface—particularly in a rather square-shaped kitchen. Are there practical tips regarding the combination of different cabinet sizes or possibly the use of Ikea-specific extensions like corner cabinets, deeper countertops, or table solutions?
Also, I am wondering if there are any special considerations during installation when aiming to significantly extend the countertop, for example with overhangs or freestanding cooking and preparation islands connected to the Metod system.
I am grateful for any advice, experiences, or suggestions that can help me successfully combine functionality with a large work surface in practice.
Secure Metod countertops with overhangs always with supports or brackets. Corner cabinets often reduce usable space. It is better to plan wide, straight fronts.
Islands should be made with continuous countertops whenever possible and supported on sturdy legs. This keeps the work surface spacious and functional.
Hello Kellin36,
I’ll summarize how I would plan an Ikea Metod kitchen to maximize countertop space, based on experience from several renovations:
1. Planning: Use the Ikea kitchen planner to precisely arrange the cabinets. Aim for cabinet widths of 80 or 60 cm (31 or 24 inches) for a uniform countertop.
2. Countertops: Choose extra-deep countertops with a width of 70 cm (28 inches) — these provide significantly more surface area and create a more spacious feel.
3. Avoid corners: Instead of complex corner cabinets, plan for open corners or peninsulas, as simple straight modules allow for more workspace.
4. Overhangs: If overhangs are desired, install metal brackets or wooden supports underneath to prevent sagging.
5. Islands: For freestanding islands, combine several cabinets and reinforce the countertop with cross braces to ensure stability.
6. Installation: Make sure to secure the countertop to the cabinets with clamps and carefully adjust the cabinet legs to create a level surface.
7. Material: Consider whether to use laminate or solid wood countertops. Solid wood is more durable for large areas.
If you keep these points in mind, you should achieve a kitchen with plenty of countertop space.
theota schrieb:
If you really want generous surface areas, you might want to consider using a different material instead of an Ikea countertop, one that’s better suited for larger spans.That may be true, but for most of us, Ikea countertops fit perfectly! If you plan properly and support the countertop well, you can achieve a lot! 👍
onMarcos schrieb:
Make sure to secure the countertop to the cabinets with brackets and precisely adjust the cabinet legs to get a level surface.Exactly, it’s all about those details. And don’t worry if the installation feels difficult at first; with patience and a bit of strength, it will turn out well. The Metod system really offers great versatility – just go for it!
And Kellin36: Also consider LED under-cabinet lighting – it really makes the large countertop area feel even more spacious! Good luck!
