ᐅ How do I build an Ikea Metod kitchen cabinet with a hidden waste bin?
Created on: 22 Sep 2020 08:13
LolebuHello everyone,
I’m planning to install an Ikea Metod kitchen unit with a waste container fully concealed under the countertop. I’m not just looking for the typical pull-out bin behind a cabinet door, but a space-saving and ergonomic solution that integrates smoothly with the cabinet front, so the waste container is neither visible nor noticeable.
Some key details about my project:
- Metod kitchen unit with 60cm (24 inches) deep base cabinets
- Planning for two separate waste containers (residual waste and paper)
- Doors with flush-front design (no visible handles)
- Preferably soft-close mechanism and smooth operation
So far, I see two options: a pull-out with internal waste bins or maybe some kind of drawer under the countertop that pulls out forward. Could anyone share their experience on the best way to achieve this? Are there Ikea-specific fittings or assembly kits that are particularly suitable? What challenges should I keep in mind during installation?
Thanks in advance for your tips and advice!
Hello Lolebu,
Your plan to build an Ikea Metod kitchen unit with a hidden waste bin is definitely feasible but requires careful planning and consideration of some technical details.
First of all, you should know that Ikea offers several internal drawer systems for the Metod series that are suitable for waste separation. These are usually mounted inside the cabinet door and include smaller inner drawers, such as the "VARIERA" sorting system, or larger internal waste containers with sliding rails.
If you want a truly concealed installation without visible handles, it becomes tricky. A fully integrated front drawer solution is difficult if the waste bin needs to be quickly accessible and the mechanism should have soft-close functionality.
My suggestion:
- Use a full-extension cabinet drawer (at least 60 cm (24 inches) wide) with damping, designed for waste.
- Mount the waste bins directly on the drawer, which slides under the countertop.
- Use a handleless front with a push-to-open or tip-on mechanism so the door pops open with light pressure.
Important to consider:
- Make sure the cabinet depth is sufficient (for Metod it’s about 56.6 cm (22.3 inches) inside, so the drawer needs to fit precisely).
- Ensure the hinges are suitable for soft-close and have enough triggering force for push-to-open.
- Check that cables or water connections (if under the sink) do not interfere.
If you’re willing to invest a bit more, third-party manufacturers also offer waste pull-outs precisely fitting Metod. It’s also worth checking Ikea’s “Ikea Meisterstücke” section for new products.
Regarding installation:
- Plan the fixing with suitable sliding rails carefully. There are height adjusters that make alignment easier.
- Install the doors first, then the drawers; verify that the front fits flush and opens without sticking.
Can you tell me how many waste bins you plan to use and whether the unit is close to the sink? This can influence the design.
If you need more details, just let me know!
My suggestion:
TYRELL schrieb:
If you want a truly hidden installation without visible handles, it gets tricky.Haha, I know that all too well! 🙂 Especially with Ikea Metod, the engineers have come up with some pretty good solutions, but this handleless thing really is a bit of a masterstroke.
Honestly, I’d prefer a good push-to-open system – it’s quick and keeps a clean line without handles. Plus, it allows for waste sorting and you don’t have to spend a fortune on expensive drawers.
If it helps, I built something similar about a year ago, and the combination of soft-close and tip-on worked really well. The important thing is that the drawer still slides smoothly – you don’t want to struggle with the trash door like a surgeon when you need to take out the waste.
By the way, if you ever want to move away from the conventional cabinet door, Ikea has had models for a while now where you can install the waste bin under the countertop and it flips up – pretty cool, but they’re rather rare and not possible with all Metod configurations.
Good luck, and keep us posted on what you decide!
Matthewt4823 Sep 2020 09:37Hello Lolebu,
I’d like to add a few basics that are often helpful when installing waste solutions in the Metod series:
- If you want to use two waste bins, it is advisable to equip a wide cabinet with two smaller containers. Ikea’s "Variera" bins are suitable for this, fit well in standard Metod cabinets, and are sturdy.
- When mounting, pay close attention to the drawer slides, as they must be securely installed and must not sag; otherwise, the front will scrape.
- For handleless fronts, it is also important that the door mechanisms are properly adjusted, because misalignment can cause the front to get stuck or the waste pull-out to have unwanted play.
- For waste sorting, it is also helpful to choose bins with matching lids that minimize unpleasant odors.
I can confirm that. The right soft-close and push-to-open mechanisms ensure smooth, trouble-free operation and make handling significantly easier.
If you have any specific questions about the installation, I’m happy to explain the individual steps.
Nauman5 schrieb:
the combination with soft-close and tip-on worked great.
Landontau23 Sep 2020 12:21Hello Lolebu and everyone interested,
Here is a summary of how I see the installation of a concealed waste bin in an Ikea Metod kitchen unit—structured and focused on mistakes to avoid:
- Preparation: Measure, measure, measure! All internal cabinet dimensions and front panels must be precise. Note the depth minus front thickness so your waste bins including the slide fit perfectly.
- Choice of slide: Ikea’s "Variera" works well, but also consider third-party suppliers that offer specialized slide systems for waste bins—often with soft-close functionality.
- Push-to-open mechanisms are almost essential for flush, handleless fronts; otherwise, you risk constantly struggling to open them.
- Installing the slide rails is one of the most critical steps:
- Ensure precise drilling and screw depth.
- Position the rails so the slide does not rub against the back panel.
- Securing the waste bins:
- Avoid loose placement—firmly screwed-in bins prevent tipping and wobbling.
- Use Ikea’s designated fixtures if available.
- Test run before attaching the front panel: perform several open and close cycles and check for smooth operation.
- Front panel installation:
- For tip-on fronts, ensure the mechanism is properly positioned.
- For soft-close, make fine adjustments as needed.
- And by the way, use your tools with precision. A cordless drill with torque control is very helpful.
Common mistakes I have seen multiple times:
- Slide rails not parallel, causing the slide to tilt or hang.
- Front panels that are too heavy or too large—overloading the mechanism.
I hope this adds more structure to your planning.
Landontau schrieb:
Guide rails not parallel, causing drawers to tilt or hang.That’s an excellent point! Parallelism is key here. I’d like to add that with Metod cabinets, you should be aware that the side panels on older models can sometimes be slightly warped, making precise alignment more difficult.
A tip: Before fully mounting the guide rails, loosely secure them with a few screws, check the alignment using a spirit level and possibly a distance gauge, then make any adjustments. Once everything fits perfectly, tighten the screws.
If you plan to use the push-to-open mechanism, be sure to test the spring tension beforehand, as it might not be strong enough later to fully open the front panel.
At the same time, I’d recommend deciding whether you want two smaller trash bins or one large one—the mounting options often vary significantly and can greatly affect the space in a 60cm (24 inch) deep drawer.
Which waste bins do you have in mind? And do you already know the exact width of your kitchen run, or is that still undecided?
