ᐅ What is the best way to secure Billy shelves to carpeted floors?
Created on: 16 Sep 2021 08:37
Z
zacharia38
Hello everyone, I have a problem that I hope someone here in the forum can help solve: What is the best way to secure IKEA Billy shelves on carpeted floors?
I understand that the traditional method of wall mounting works well on solid, dry floors, but my floor is a thick carpet, and I want to fix the shelf securely and stably without it wobbling or tipping over.
Has anyone had experience with fastening methods specifically for carpeted floors? Are there special wall anchors or other tips you can recommend? I’m looking for a safe solution that leaves as little damage as possible and isn’t too complicated. Thanks in advance!
Takutau
17 Sep 2021 10:47
zacharia38 schrieb:
Which anchors are best suited to ensure they hold firmly when used with the heavier shelf?
I would also recommend fixing the shelf to the wall at least at two points, preferably evenly spaced along the height of the shelf.
Additionally, before drilling, you can use a small nail or needle to check where the drywall behind the surface is most suitable. It’s equally important to use the correct drill bit size for the anchors to ensure optimal grip.
If you want extra stability, you can also use the supplied brackets at the bottom of the shelf to secure it to small partition walls or nearby furniture.
sarGabriel
17 Sep 2021 14:53
As a tip for alignment before fixing – place the shelf on the anti-slip pads, align it precisely, and only then attach it to the wall. This helps prevent it from wobbling after installation.
Karsten45
18 Sep 2021 08:28
Hey, after all the input, I specifically ordered rubber mats and tested my Billy bookshelf on carpet. And what can I say? The combination with the wall brackets works great. A little anecdote: At first, I thought such a heavy shelf couldn't tip over – but I was wrong! With the right fixings, it’s secure. 😉
JAMESONB41
18 Sep 2021 11:40
Karsten45 schrieb:
With the right mounting, it works.
Exactly, better to secure it properly first than risk the shelf tipping over. Safety comes first.
