ᐅ What is the best way to combine Ikea PLATSA and PAX?
Created on: 30 May 2020 18:23
Arenle
Arenle
30 May 2020 18:23
I am planning to optimize my living space organization using systems from Ikea and have been considering the two cabinet series Platsa and Pax. My main question is: How can I best combine Ikea PLATSA and PAX to create a functional and visually coherent storage solution? I am interested both in structural adjustment options and recommendations for integrating the two series, for example regarding heights, depths, and built-in components. Should there be an emphasis on a harmonious overall look, or is it perfectly fine to place the two series side by side even if they have different appearances or dimensions? I have a room with limited width but want to maximize storage capacity. I would also appreciate tips on proven interior fittings or accessories.
Genuan
30 May 2020 19:11
The most important rule is that PAX and PLATSA have different depths, which affects the planning. It is best to place them side by side so that the fronts are aligned at the same level to create a unified appearance. Avoid connecting them directly, as the constructions are not designed for that. Inside, you can use the PAX systems more generously for clothes rails and drawers, while PLATSA is more flexible for custom solutions.
DUKUSU
31 May 2020 07:42
Oh, this is a really cool project! The combination of PLATSA and PAX opens up a lot of possibilities, especially when you get creative! 😃 One tip: use the flexibility of PLATSA for corners or irregular room shapes, while PAX is perfect for larger, more standard storage areas. Try creating a connection using colors or handle options – it really makes a difference! Keep it up, this will turn out great 😄!
Kyler10
1 Jun 2020 10:37
There are several important considerations for the structured combination of Ikea PLATSA and PAX systems: Both systems differ technically, especially in terms of depth – PLATSA is typically 35 cm (14 inches), while PAX is usually around 58 cm (23 inches). This means that a direct connection in depth is problematic and the systems will not align flush. Therefore, it is advisable to plan them either along different walls or to visually connect them using small construction or cover elements. Another point is functionality: PAX is ideal for clothing storage with standardized interior components (drawers, clothes rails, etc.), whereas PLATSA, with its modular frames, offers great flexibility to adapt to niche and room dimensions. Accordingly, your planning should take into account the specific strengths of each system and not necessarily force a fully integrated unit. For the interior design, it is important to ensure a consistent front design in order to create a harmonious overall appearance.
