ᐅ How can I avoid mistakes when installing Ikea Metod drawers?
Created on: 24 Mar 2021 09:17
Emilfo
Emilfo
24 Mar 2021 09:17
Over the past few weeks, I have tried several times to assemble Ikea Metod drawers, and I made some mistakes that prolonged or complicated the entire assembly process. My question is: What specific steps and tips would you recommend to avoid common errors when assembling Ikea Metod drawers?
I am especially interested in the following points: How can I ensure that the drawer fronts are properly aligned, which tools are useful, and how can I prevent the runners from sticking or being installed unevenly? Also, I would like to know if it is advisable to prepare individual components first or to assemble the entire drawer at the end.
I look forward to your experiences and advice!
Elodie
24 Mar 2021 09:42
Hey Emilfo,
great that you’re already approaching this so thoroughly! 😄
First tip: patience is definitely needed with the Metod drawers. It really helps to lay out all the parts and sort them according to the instructions—like a puzzle in front of you. The included Allen key is usually sufficient, but having a small Phillips screwdriver makes you more flexible.
It’s important to install the rails perfectly straight and not to overtighten the screws—they should be secure but not stripped. Use the adjustment options at the mounting points to fine-tune the front alignment. If it still sticks, check if anything is caught between the rail and the drawer.
And yes: assembling components partly in advance usually makes the process smoother than building everything step by step. Small intermediate checks help catch errors early!
Good luck, you’ll manage it! 🍀
BOLUKEO
24 Mar 2021 10:05
Measure drawer slides precisely and install them using a spirit level.
Do not overtighten the screws.
Adjust the front panel carefully only after hanging it.
Tools: Allen key and screwdriver.
renpeo
24 Mar 2021 11:26
Hello Emilfo,
I would like to address your question and summarize a few helpful points from my experience with Ikea Metod drawers.
- Take your time unpacking and organize all parts according to their function. This helps prevent mix-ups.
- Pay close attention to the alignment of the drawer slides and use a spirit level, even a small one.
- Always install the slides on the cabinet side first, then on the drawer. This makes fitting them later much easier.
- Tighten the screws carefully, as overtightening can damage the mechanism or cause the drawer to stick.
- The drawer fronts are only adjusted at the very end, using small screws for fine tuning.
If you notice that the drawer sticks anywhere or doesn’t slide smoothly, first check the drawer slides and make sure nothing is bent or twisted.
I’ve gotten into the habit of planning the entire assembly in stages – this way you can check each step and end up with less rework.
If you like, I can also provide you with step-by-step tips!
Elodie
24 Mar 2021 12:37
renpeo schrieb:
I have gotten into the habit of planning the entire construction process in stages – this way you can check everything at each step and end up with less rework.
That’s a great tip! It reminds me that last time I did everything all mixed up and had to adjust five times in the end.
A smooth sequence and short breaks in between made all the difference for me. And hey, who says building furniture can’t be fun? 😇
V
vin_leo
25 Mar 2021 08:44
I can only confirm that adjusting the drawer front at the end can be quite a challenge. My tip for this:
- When attaching the front, always make sure that all fastening points are evenly aligned.
- Don’t be discouraged if the front looks crooked on the first try; the small adjustment screws are real lifesavers!
- Also, I find having a second person to help when mounting the drawer is great, as it makes it much easier to check the alignment of the fronts.
And the really cool thing is: once you get the hang of it, everything goes much faster and you end up feeling like a pro. 😊
