ᐅ How can I securely install Ikea Metod kitchen cabinets on uneven walls?
Created on: 13 Jun 2020 09:13
gifar
Hello everyone, I have a complex question regarding the installation of Ikea Metod kitchen cabinets on uneven walls. Unfortunately, my kitchen walls are not straight and have significant irregularities, which make it difficult to mount the cabinets flush. My goal is to securely and stably attach both the upper and base cabinets without any tilting or gaps between the furniture and the wall afterward.
Has anyone dealt with similar situations and can offer tips on effective techniques or tools for mounting? I am especially interested in:
- What is the best way to accurately measure the wall unevenness and take it into account during installation?
- Are there specific fixing systems or materials suitable for correcting wall deviations?
- How should I adjust the cabinets to ensure they look clean and function properly once installed?
Thanks for any helpful answers or additional advice!
gifar
13 Jun 2020 10:38
Genevieve schrieb:
Wouldn’t it be more practical to skim coat the wall before installation or at least partially smooth out minor irregularities to ensure long-term stability?
That is indeed an option I am carefully considering. However, I want to avoid major renovations and prefer, if possible, a pragmatic solution that relies on the mounting system. The idea behind this is that my walls are very uneven – in some areas even with ribs and layers in the plaster – where filler only helps to a limited extent. Therefore, I am looking for a method that uses adjustable components and wedges but still appears sufficiently stable.
lochen
13 Jun 2020 11:12
I would like to add: If you have very extreme unevenness, it is advisable to first install a straight counter batten. This can be securely fixed to the wall using the appropriate anchors and screws. Then, you mount the Metod cabinet hanging rails onto this batten. This provides a straight base that compensates for any uneven walls.
This method is well proven and makes adjusting the cabinets easier. By the way, the counter batten is also useful if you want to disassemble and relocate the furniture later.
karbar
13 Jun 2020 11:45
Counter battens are a good solution! Simple, practical, and sturdy. Additionally, this allows you to install the hanging rails accurately aligned.
liste
14 Jun 2020 08:09
lochen schrieb:
If you really have very extreme unevenness, it is recommended to first install a straight counter batten.
I agree, this is a common practice. However, it would be interesting to know how this counter batten performs on walls made of different materials (e.g., drywall vs. brick). Are standard wall plugs sufficient, or should special solutions be used? The wall’s load-bearing capacity also matters, since Ikea Metod cabinets can be quite heavy when fully loaded. What use is the best counter batten if the fixing doesn’t hold?
Therefore, my question is: What are your experiences regarding wall plugs and fastening materials specifically for uneven walls with different substrates?
SETHBLA
14 Jun 2020 08:34
For drywall partitions, I strongly recommend using metal special anchors or hollow wall anchors.
For brick or concrete walls, heavy-duty anchors are appropriate. It is always important that the anchor is rated to support the weight of the fully loaded kitchen.
