ᐅ How do I secure Ikea Metod kitchen cabinets to different types of walls?
Created on: 15 Apr 2019 09:37
Gone44Hello everyone,
I am currently planning the installation of an Ikea Metod kitchen and face the challenge of securely and permanently fixing the kitchen cabinets to different types of walls. These walls include not only standard concrete but also drywall, brickwork, and partly gypsum board. My question is: what fastening methods and materials are best suited for these different wall types to ensure the stability of the Ikea Metod kitchen units?
In particular, I am interested in whether it is better to use special anchors for drywall, or if additional reinforcements are necessary. Are there specific tips for mounting on brick walls that I should consider—such as drilling techniques or the choice of anchors? Also, what is the general situation regarding possible weights the units might carry if only standard fasteners have been used so far?
I would be very grateful for practical experience and recommendations, including advice on trusted brands or types of anchors and screws. Thank you in advance!
Hello Gone44,
your question is very well formulated, and I can provide you with a structured guide on how to safely mount Ikea Metod kitchen cabinets on different wall types.
1. Concrete walls:
- Drilling is generally possible without issues here. It is best to use a hammer drill and anchors such as Fischer UX or similar quality products.
- Use anchors with an appropriate diameter, usually 8 mm (0.3 inches), to safely support the load.
- Screws should be long enough to securely connect both the anchors and the cabinets.
2. Brick masonry:
- Use drill bits designed for masonry.
- For solid bricks, the procedure is similar to concrete, but for hollow bricks, cavity anchors that expand inside the void are recommended.
- Alternatively, toggle bolts or metal anchors provide better support.
3. Drywall (gypsum board) walls:
- Caution is necessary here. Standard plastic anchors are usually not suitable.
- Use special cavity anchors, drywall anchors, or metal anchors.
- Important: Whenever possible, distribute the cabinet load onto the stud (metal profile or wooden batten) behind the drywall panel.
4. General tips:
- For heavy kitchen cabinets like Metod, always use multiple mounting points.
- Before drilling, always check for electrical wiring or plumbing pipes with a stud finder or similar detector.
- It is advisable to align fastenings with studs or solid parts of the wall.
Summary: For every wall type, there are suitable anchors and screws. Stability is achieved by using enough mounting points, appropriate anchors, and distributing the load onto load-bearing wall areas.
If you want, I can also provide specific product examples. Are you planning to install the Metod kitchen cabinets freestanding, or will you mount them on the wall?
1. Concrete walls:
2. Brick masonry:
4. General tips:
REPITAR schrieb:
Are you planning to install the Metod kitchen cabinets as freestanding units or will they be wall-mounted?Thank you for the detailed response, REPITAR! Yes, the cabinets need to be wall-mounted because I want to secure the kitchen run to the walls to ensure maximum stability and evenness.
In addition to your explanation, I have a question about drywall installations: Is it common to use wooden battens on the wall as a support and fastening aid? I often see people installing battens somewhere behind the wall structure—is this highly recommended for Metod, or not absolutely necessary?
Also, I’m curious whether special screws or anchors are required for attaching the cabinet carcass to drywall panels, or if the cabinet mounting is theoretically done solely through the cabinet base. The cabinets can be quite heavy, especially when equipped with appliances and a countertop.
Are there general recommendations on how to properly distribute the weight of Metod kitchen cabinets on different wall structures to avoid long-term damage to the walls?
Hello Gone44,
Regarding the wall mounting of your Ikea Metod kitchen cabinets, I can provide some technical details and recommendations to help you securely attach them to various wall types:
1. Use of wooden battens behind drywall:
- Yes, installing wooden battens or metal profiles behind the drywall is a very practical and commonly used method.
- These so-called mounting battens provide a stable anchor because screws hold better in wood than in drywall alone.
- This allows the weight of the kitchen cabinets to be distributed more effectively onto load-bearing elements.
- Ideally, these battens are installed during the wall construction or beforehand. Retrofitting them later is often difficult.
2. Fixing to gypsum boards:
- Standard drywall anchors (also called hollow wall anchors) are a must, but they are often insufficient for heavy loads such as a fully equipped kitchen.
- Metod kitchens are typically secured to the wall using heavy-duty anchors in a solid substrate.
- The cabinet itself usually rests partly on the floor, while the wall mounting provides the necessary stability and safety.
- Therefore, a combination of floor support and wall mounting is optimal.
3. Weight and load distribution:
- To distribute the load from cabinets and appliances, it is recommended not only to mount onto battens or profiles but also to use multiple anchor points per cabinet.
- Avoid placing all the weight on just a few anchors.
4. Drilling and fastening techniques:
- For brick walls, drill holes at least 10-12cm (4-5 inches) deep, using suitable anchors such as expansion anchors or toggle bolts.
- Avoid special plastic anchors for aerated concrete – in this case, sleeve anchors are a better choice.
I hope these tips help you further. If you like, you can also mention the exact wall thicknesses and wall constructions – this allows for an even more precise recommendation of the appropriate fastening method.
