ᐅ How can I attach IKEA Metod countertops to different types of walls?
Created on: 10 Jul 2015 14:23
LiforonHello everyone, I am currently planning to install an IKEA Metod countertop, but my kitchen has different types of wall surfaces. Specifically, it is a combination of brick, drywall (also known as plasterboard), and in one spot, concrete. My question is: How can I securely and permanently fasten the Metod countertop to these different wall materials? What fastening methods are recommended to ensure both stability and to protect the countertop from premature wear or damage caused by incorrect installation? Are there any differences in choosing the fastening hardware depending on whether I am mounting to brick, drywall, or concrete walls? I would appreciate detailed advice as well as recommendations on tools or special brackets that have proven effective.
Hello Liforon, your question is very well posed and offers several points to consider. Basically, the types of fasteners vary significantly depending on the wall material. I will describe this step by step:
- For brick walls, it is advisable to use special hammer-in anchors or chemical anchors. The countertop is quite heavy, especially with longer boards, so you should use strong anchors that grip well in the brick.
- For drywall (gypsum board) walls, fastening is more complicated since the drywall alone does not provide enough stability. Here, you definitely need a supporting framework, for example wooden battens or metal profiles, ideally attached to the load-bearing studs behind. Then you can mount the countertop to the substructure using appropriate angle brackets.
- For concrete walls, heavy-duty anchors that can handle the load are best. In this case: pre-drill with suitable concrete drill bits, then install the anchors.
It is also important to measure the countertop carefully beforehand and, if necessary, align it with a spirit level. For mounting, besides brackets, so-called support strips can also be used—narrow strips fixed to the wall under the countertop that support it.
Can you say how long the countertop will be and whether you have a continuous wall or, for example, a partial wall with drywall? That would help to give even more precise recommendations.
leebi7 schrieb:
Attaching to drywall is more complicated because drywall alone does not provide enough stability.I have to strongly disagree. Of course, drywall isn’t the strongest wall type, but there are toggle bolts or specialized hollow wall anchors designed for such applications. The emphasis here is on ‘properly sized.’ Anyone who tries to just put a regular anchor into drywall will fail, obviously. But with the right hollow wall anchors, a secure attachment to drywall is possible without extensive wooden framing. You just shouldn’t cut corners or try to save money in the wrong place.
Still, the question remains how heavy the panel actually is and what kind of load is expected.
Hello Liforon, I would like to add some information to look at the different types of walls from another perspective. Especially for kitchens and countertops, it is important to allow the wall and the mounting method a certain load capacity. Your countertop should not only support its own weight but also withstand the stress from cutting, placing objects, etc.
- Brick: As mentioned, impact anchors are a very good solution. I personally always use dowels of at least 10 mm (0.4 inches) for countertop installation, depending on the wall thickness.
- Drywall (plasterboard): Make sure to check behind the drywall – if possible, screw directly into the studs. If that is not possible, it is better to attach a batten to create a solid supporting base.
- Concrete: Heavy-duty anchors are always the first choice here. Please use good-quality drills, and always pre-drill using the hammer drill function, as this helps a lot.
Tools: Apart from a drill, you will need a proper spirit level, clamps (to fix the countertop while screwing), and possibly expanding foam if sealing is involved.
I hope this helps. If you have photos of the room, feel free to provide a more detailed description so we can assist you better.
Thanks for your previous tips! The countertop will be about 2.80 meters (9 feet 2 inches) long, running along the brick wall and ending at a drywall partition. The concrete wall is only a small section next to the kitchen area, about 40 cm (16 inches) wide. So, I basically have three different fixing points:
- 2 meters (6 feet 7 inches) brick wall
- 0.40 meters (16 inches) concrete
- and 0.40 meters (16 inches) drywall
So far, I don’t have a substructure but could install a lightweight wooden batten framework on the drywall. The countertop should withstand typical kitchen loads but nothing extreme, just normal household use. My main concern is the drywall partition since it’s a bit old and probably not very stable. Would a support strip on the drywall be sufficient, or is it better to have an additionally reinforced substructure? And which anchor brands or types have you found particularly reliable? Thanks in advance!
Liforon schrieb:
Is a support strip on the drywall sufficient, or is a reinforced substructure better?If the drywall is old and not very stable, I strongly recommend a reinforced substructure. A simple support strip is only enough if you can securely screw into the wall studs. Without solid anchoring there, the load is too great.
For the wooden framework, I suggest using wood battens with a cross-section of at least 40 x 60 mm (1.5 x 2.4 inches), which you attach perpendicular to the wall onto the studs. The countertop will then rest directly on these battens and can be additionally secured with angle brackets.
Regarding anchors, brands like Fischer or Spax are very reliable. For drywall with cavities, I recommend special cavity anchors with a large bearing surface—for example, Toggler Snaptoggle XL or Fischer DUOPOWER.
If you want to be extra sure about fastening into the drywall, you can also screw short screws through the countertop directly into the wood battens—this increases stability and the feeling that nothing will wobble.
What about your tools? Do you have a decent hammer drill?
