ᐅ How can I attach IKEA Metod countertops to different types of walls?
Created on: 10 Jul 2015 14:23
Liforon
Hello everyone, I am currently planning to install an IKEA Metod countertop, but my kitchen has different types of wall surfaces. Specifically, it is a combination of brick, drywall (also known as plasterboard), and in one spot, concrete. My question is: How can I securely and permanently fasten the Metod countertop to these different wall materials? What fastening methods are recommended to ensure both stability and to protect the countertop from premature wear or damage caused by incorrect installation? Are there any differences in choosing the fastening hardware depending on whether I am mounting to brick, drywall, or concrete walls? I would appreciate detailed advice as well as recommendations on tools or special brackets that have proven effective.
Muso4
11 Jul 2015 11:17
Liforon schrieb:
My main concern is the drywall because it’s quite old and probably not very stable.
I wouldn’t underestimate that either. "Old" often means the drywall is more brittle and may have been damaged by previous stresses. Therefore, I recommend not relying solely on anchors for the drywall side. A lightweight wooden frame would be invaluable – it helps distribute the load.
leebi7 schrieb:
Wooden battens with a cross-section of at least 40 x 60 mm (1.6 x 2.4 inches)
Yes, I think that makes sense, even if it’s not very elegant visually. But stability is more important.
For the brick wall: It’s worth using a drill with a hammer function. By the way, it’s advisable to spend a bit more on the anchors you choose instead of cheap ones from the hardware store. Especially when dealing with different wall types, quality anchors are crucial.
And for the tools: Having a vacuum cleaner nearby while drilling makes the work much more pleasant.
