ᐅ Recommendation for anchors or similar fasteners for mounting on drywall partitions
Created on: 12 Jan 2021 09:16
Appel2000
Good morning everyone,
Here is the situation:
Bathroom
A drywall partition with metal studs
Double-layered and additionally reinforced with wood/OSB at (hopefully) the crucial points
Tiles are already installed
Now, a wall-mounted vanity cabinet with a washbasin is to be installed here.
Unfortunately, I’m concerned we didn’t consider the weight enough.
My gut feeling says it should hold, but I don’t want to rely on that alone and prefer to be as safe as possible.
According to the installation instructions, the cabinet should be screwed to the wall at a total of 8 points.
I am now looking for the "best" anchors/screws/fastening options suitable for this purpose.
Classic metal hollow wall anchors from F....?
Or are there other alternatives?
Thanks for your advice,
best regards
Bathroom
best regards
Appel200012 Jan 2021 23:36Hello everyone,
I unfortunately need to bring up this topic again.
I checked the construction once more today.
The build-up from outside to inside is as follows:
- Tiles
- One layer of drywall
- Several layers of wood (we really meant well here, I hadn’t realized it was that much)
- Then comes the cavity
In total, from the top edge of the tiles to the cavity, it is definitely about 75mm (3 inches) that the anchor/screw needs to penetrate.
Looking at the common sizes of metal hollow wall anchors, I’m a bit concerned that they might not be able to expand properly behind all that material because they could be too short.
Or should anchors with a length of 80mm (3 1/8 inches) be long enough to expand securely?
Thanks,
Best regards and good night!
- Tiles
Thanks,
