ᐅ How can I assemble Ikea PLATSA modular units for flexible use?
Created on: 10 May 2016 08:37
Kabastian
Kabastian
10 May 2016 08:37
Good morning everyone,
I am currently planning to set up a flexible shelving system using Ikea Platsa and am looking for advice on how to design it modularly so that I can easily add, change, or rearrange parts in the future.
I am especially interested in which basic components work best together to cover different storage needs (e.g., open compartments, closed cabinets, drawers). Stability is also important to me despite the modularity, and I would like to know the best ways to support the system when expanding it later on.
Has anyone had experience with the flexible use of PLATSA and can offer recommendations on the setup—particularly regarding which connection or assembly methods are suitable for easy adjustments?
Thanks in advance for your help!
Penau
10 May 2016 09:18
Hello Kabastian,
for flexible assembly of Ikea PLATSA, I recommend the following approach:
- First, select the base frames (basic elements) from the series that are required for the planned use. There are different depths and heights. These form the structural foundation.
- Use the supplied connecting fittings and add concealed angle brackets if needed to ensure stability for larger module configurations.
- Modularity means you can replace individual components like drawers and compartments at any time, so avoid gluing or permanent fasteners.
- Plan the system thoughtfully with possibly open compartments for frequently used items and closed doors for storage.
- For larger setups, attaching the units to the wall using the supplied brackets is advisable for increased safety and stability.
This way, you can adapt PLATSA to changing needs without major modifications.
benonon
11 May 2016 12:04
Hello Kabastian,
I would like to add to Penau’s comments with a deeper technical insight, as modularity in PLATSA primarily depends on the interaction of the individual modules and their assembly.
1. Planning: Start with a detailed room measurement and plan based on the standardized widths (60cm (24 inches), 40cm (16 inches)) and heights of the PLATSA elements. Pay particular attention to ensuring all modules stand on level surfaces, as unevenness can lead to instability.
2. Types of connections: The metal brackets supplied by Ikea are easy to install but limit module repositioning. For flexible reconfiguration, I recommend screw connections with wing nuts or quick-release clamps, which allow for greater flexibility in some corners.
3. Wall mounting: Secure wall mounting is essential, especially if you want to expand the system. Without wall mounting, the risk of tipping increases significantly.
4. Interior fittings: PLATSA offers various inserts – drawers, shelves, doors. Consider before assembly which combination makes the most sense for you now, and leave space for future modules.
5. Typical mistakes:
- Neglecting to level the floor often leads to wobbly modules.
- Screwing all modules together without separation prevents flexibility later on.
For even greater long-term flexibility, I recommend not gluing or permanently screwing the individual modules together during assembly, but instead using plug-in elements wherever possible.
Question: What is the size of your planned space and how much load do you expect the shelves to carry? This can influence the choice of modules and fastening methods.
Kabastian
11 May 2016 16:47
benonon schrieb:
Question: What are the dimensions of your planned space and how much load do you expect to place on the shelves? This can affect the choice of the module and the mounting methods.
Thank you for the detailed advice, benonon. My planned area is approximately 2.40 meters (7 ft 10 in) wide and 2.20 meters (7 ft 3 in) high. It will mainly be used for storing smaller items (books, decorations, tech accessories), but occasionally heavier loads like boxes with tools or electronics. I expect an evenly distributed load, but nothing extremely heavy.
It is important to me that the construction remains easy to adjust while also being sturdy enough to support a reasonable amount of weight.
I also noticed that the depth of the individual units is either 40 centimeters (16 inches) or 60 centimeters (24 inches). Does anyone have experience whether the deeper option is always more stable, or if it’s better to choose the shallower depth depending on the intended use?
Lyndon55
12 May 2016 10:23
Hello Kabastian,
Regarding modularity and stability with PLATSA, I can offer you a brief guide based on your information:
1. Choice of Depth:
- 60 cm (24 inches) depth provides more storage space but is heavier and can become less stable if not properly secured.
- 40 cm (16 inches) depth saves space and offers more stability in the construction, especially when wall mounting is done correctly.
2. Combination Options:
- For flexible use, I recommend combining both depths—60 cm (24 inches) at the bottom for larger items, with 40 cm (16 inches) shelves above for books and smaller objects.
3. Installation:
- Make sure to wall-mount all taller modules to prevent tipping and enhance safety.
- Use the original bracket connectors for the units to screw the modules together without creating a permanent connection. This way, adjustments are always possible.
4. Loads:
- Ensure that the load in the 60 cm (24 inches) deep cabinets (especially with multiple shelves) is distributed as evenly as possible.
- For heavier loads, plan for additional cross braces or reinforcements.
Summary:
- A width of 2.40 m (7 ft 10 in) and height of 2.20 m (7 ft 3 in) work well for combining several modules.
- A staggered system of 40 cm (16 inches) and 60 cm (24 inches) depths is optimal for flexibility and stability.
- Wall mounting and modular screwed connections are essential.
Careful planning and precise installation are key for successful, flexible use.
