Hello everyone, I plan to assemble an Ikea Pax wardrobe in a very tight space. The room’s height and width leave hardly any room to move, especially when putting together the side panels and the back panel.
My main question is: What strategies or tips do you have for safely and efficiently assembling large furniture like the Pax in small, confined spaces? Are there specific steps, tools, or techniques you would recommend when there is very little room to maneuver?
I appreciate any help!
It is definitely helpful to assemble the cabinet frame completely first, but only loosely screw it together. Final fixing should be done in the room. Install the back panel really as the very last step! Carpenter’s squares or small wedges can help stabilize the cabinet while aligning it.
Josan schrieb:
If space is limited, you can also leave parts of the cladding or doors off initially and install them after assembly.That exactly helped me the most. For example, I attached the doors to the wall-mounted cabinets at the end. It saves a lot of space.
Also: Good lighting is worth its weight in gold in a small room because it prevents rushed movements and allows for more precise work.
Let's be honest: people often make things harder than they actually are. The Pax wardrobe is large, yes, but in a small room it's clearly a case for planning in advance. My tip: measure the room, mark the space on the floor, and plan the assembly outside the room. I often see people who think they can manage it on the fly. Spoiler: better to plan once than to complain twice.
GEKAU51 schrieb:
My advice: measure the room, mark the floor area, and plan the assembly off-site.I didn’t do this in detail due to lack of time, but your input confirms that I should proceed carefully.
Thanks to everyone who recommended installing the back wall last and emphasized assembling in parts. I will definitely try that and follow all the advice about having an extra pair of hands, proper lighting, and small tools.
One last quick question: Are there any special considerations when using cordless screwdrivers in such tight spaces?
