Hello everyone, I am currently looking into how stable the Ikea Platsa furniture really is when assembled without the back panel. I understand that the back panel primarily contributes to stability and helps prevent wobbling and warping. In my research, I found differing opinions on how much the back panel actually stabilizes the piece of furniture. Therefore, I would be interested to know if you have any experience or technical insights on how robust the Platsa modular furniture can be when used without the back panel. For example, I’m curious whether the furniture tends to tip over easily or if the construction and materials provide other stabilization mechanisms. It would also be helpful to know if the risk increases that the hinges might warp or the doors do not close properly. Thanks in advance for your feedback.
peovin schrieb:
Without a back panel, Platsa can become unstable, especially with larger units. That is correct. The back panel is essential for Platsa’s stability, as it reinforces the furniture and prevents lateral movement.
Additionally, it should be noted that constructions without a back panel are much more vulnerable to all types of stress, especially when the unit is tall or wide. Using it without a back panel alone therefore requires additional fastenings to maintain the hinges and the cabinet shape and to avoid wobbling.
Luciandi schrieb:
I tried it myself and found that furniture without a back panel is somewhat less stable, especially under heavy load. Thank you for the honest assessment. I am also interested in how it performs when loaded with heavy items, such as electronics or books. Does it twist easily in that case, or do additional fastenings keep it within acceptable limits?
juethan schrieb:
I am still interested in how this performs under heavy loads, for example with equipment or books? Heavy loads without a back panel can cause deformation, especially on the top and bottom boards. Mounting to the wall and using additional brackets are essential in these cases. Without these measures, the load-bearing capacity decreases significantly, and both doors and hinges experience increased stress due to the uneven load.
