ᐅ How do I install Ikea Metod cabinets on uneven wall dimensions?
Created on: 11 Nov 2016 08:14
bitorsten
bitorsten
11 Nov 2016 08:14
Hello everyone, I am currently assembling Ikea Metod kitchen cabinets in my new apartment, but I’m facing a problem: the walls where the cabinets are supposed to be mounted are not completely straight or even. Specifically, the wall measurements vary, meaning there are deviations of a few centimeters (inches) along the length of the kitchen. My question is: How do I install Ikea Metod cabinets on uneven walls in a way that still results in a neat, precisely fitting, and securely mounted setup? Are there proven methods, tricks, or special accessories to compensate for these irregularities? I’m also open to recommendations on the best way to measure, assemble, and adjust the cabinets so that they end up straight against the wall without gaps or spaces. Thanks in advance for your tips!
Faben53
11 Nov 2016 08:53
Hello bitorsten, your issue with uneven wall dimensions when installing Ikea Metod cabinets is quite common, especially in older buildings or apartments. As a basic step, I recommend first measuring the wall very accurately using a laser measuring device or a spirit level combined with a tape measure to identify the exact spots with irregularities.
A tried-and-true tip is not to align each cabinet rigidly against the wall initially, but first connect the cabinets to each other and adjust their fronts to fit together. Only then do you mount the entire cabinet assembly to the wall. This approach helps to compensate for gaps.
If the wall is crooked, use adjustable legs (Metod cabinets come with these from the factory), and it is often recommended to install a batten structure on the wall as well. This can be mounted to compensate for unevenness and provides a secure framework to hang the cabinets on later.
Some people also use service strips or small wooden wedges behind the cabinets to level out minor unevenness. The key is not to be too rigid during installation but to plan flexibly.
PLOMA
11 Nov 2016 14:37
Faben53 schrieb:
A proven tip is not to fix the individual cabinets rigidly to the wall at first, but to connect the cabinets together and align the fronts with each other. Only then do you mount the entire cabinet unit to the wall. This way you can compensate for gaps.
Exactly, that’s the key. I would elaborate on this in more detail:
- First, I recommend fully assembling all modules and connecting them with linking hinges. IKEA also offers special fastening materials that help to securely join the cabinets together.
- Then, the entire assembly should be checked with a spirit level and a straightedge. Uneven areas can be adjusted by fine-tuning the METOD adjustable feet, which are precisely adjustable.
- For large wall irregularities, a mounting batten, for example a wooden construction, can be attached to the wall. This batten is aligned level and then serves as a support or fixing rail for the cabinets.
- To work accurately, I suggest creating a measurement sketch and measuring the wall-floor-cabinet corners. Especially with uneven walls, it’s advisable to leave some clearance during installation and use filler strips to visually cover gaps.
- Important: Also pay attention to the distance from the countertop edge so that the work surface remains level. If the wall measurements differ at the top and bottom, a small gap can be compensated by the adjustable feet or by using narrow side filler panels.
Do you have more specific deviations? Measurements in centimeters would be helpful.
bitorsten
12 Nov 2016 07:26
PLOMA schrieb:
Are there more specific deviations on your side? Measurements in centimeters would be helpful.
Thank you for the detailed explanation, PLOMA. Yes, I can be a bit more precise: The total kitchen length is about 360 cm (142 inches), but the wall width varies slightly because it is slightly curved and not completely straight. At one end, the wall measures 363 cm (143 inches), and at the other end 358 cm (141 inches), so there is a difference of about 5 cm (2 inches). Also, the side walls are not exactly perpendicular; I estimate a deviation of about 2-3 degrees.
My concern is that I might not be able to fit the Metod cabinets, which come in fixed widths (e.g., 60 cm (24 inches), 80 cm (31.5 inches)), tightly side by side. Is there a way to visually and functionally close small gaps well, or should I try to custom-fit a cabinet down to the millimeter? Or would it be better to omit individual modules and work with side panels and filler pieces on both sides?
How much tolerance do these cabinets really allow during installation? Is it common to work with cut-to-size pieces, or should one strictly use only the standard modules?
lubla
12 Nov 2016 09:01
With a difference of about 5cm (2 inches) and an angle of 2-3 degrees, I would not use modules to compensate for the wall but rather use trim and filler pieces. Use the adjustable feet to level everything properly.
For Metod, there are suitable filler pieces that can be attached to the sides of the cabinets to cover small gaps. For more pronounced bulges, a mounting strip on the wall helps.
KarTristan
12 Nov 2016 11:47
bitorsten schrieb:
My concern is that the Metod cabinets, which are sold in fixed widths (e.g., 60 cm (24 inches), 80 cm (31.5 inches)), might not fit side by side exactly as planned.
That is a valid concern. Metod cabinets come in standardized sizes, but that doesn’t mean adjustments aren’t possible. Generally, I recommend not forcing the cabinets side by side in a rigid line against the wall, but rather planning the order and placement flexibly.
- Allow space for filler panels, which are available in various widths and are easy to install.
- Cover panels can also be used to create smooth visual transitions.
- If the walls are not perfectly square, check the cabinet alignment with a protractor before installation.
It’s best to keep the standard modules intact, but additional adjustments are useful. Typically, cutting Metod cabinets is avoided to maintain warranty and proper fitting.
