Hello everyone, I am currently working on a project to assemble several IKEA Metod kitchen cabinets with soft-close drawers. I want to ensure that the assembly is not only neat and sturdy but also that the soft-close function of the drawers works optimally afterwards. My specific question is: Are there any special tips or steps to keep in mind when assembling the Metod cabinets with the soft-close drawers, especially regarding the installation of the drawer slides, adjusting the damping, and the correct alignment of the fronts? I would also appreciate any advice on how to avoid common mistakes that could affect the soft-close mechanism. I have already reviewed the IKEA instructions, but sometimes the guidance is a bit brief. Thanks in advance for your suggestions!
Regarding the weight capacity for soft-close drawers: the IKEA Metod system is designed for typical kitchen loads. If your drawers become very heavy, the soft-close mechanism may reach its limits – in that case, only more heavy-duty slides or IKEA’s special heavy-load options will help.
Otherwise, make sure the drawer is properly engaged when inserting it. If it sticks, the slide or the damper may not fit perfectly.
reoWilhelm25 Dec 2018 09:42I’ll quickly join in – I think installing the fronts is often the underestimated part. The adjustment options with Metod are great, allowing you to:
- Adjust the front sideways,
- change the height of the front,
- and fine-tune the tilt.
If you have a front that doesn’t close perfectly straight, you can almost always fix it without removing the entire drawer. By the way, the soft-close function only works if everything is perfectly aligned – otherwise, it will either close hard or stay open.
My tip: really take your time with this fine adjustment; I’ve gained a lot from it.
ploon schrieb:
How can I precisely tell if the drawer slides are installed correctly?Reliable reference points are the existing grooves and drill holes intended for positioning. In addition, you should check:
- The parallelism between the left and right slides using a ruler.
- The squareness of the slides relative to the cabinet bottom with a protractor.
- The smooth vertical movement of the drawer, to prevent the slides from jamming.
Measuring tools are always more helpful than just relying on visual judgment. If you have a precise spirit level, that is also very suitable.
Regarding weight and soft-close: Adjustment via the regulator or shifting the damper is limited with Metod. For extremely heavy drawers, it may be advisable to add reinforcements or use professional-grade drawer slides.
reoWilhelm schrieb:
If you have a front panel that doesn’t close completely flush, it can almost always be fixed without removing the entire drawer.This is important! Many people underestimate the adjustment options.
Here is a brief checklist for mounting and adjusting the front panel:
- First, simply insert the front panel and roughly align it.
- Then turn the side adjustment wheels and check if the front is flush with the cabinet body.
- If there is any tilt at the top or bottom, use the tilt adjustment to correct it.
- Finally, check that the front does not rub or jam when opening and closing.
By following these steps, you can prevent later functional issues with the soft-close system. The smooth interaction of all parts makes the difference!
