ᐅ Making IKEA Metod Drawers Close More Quietly and Smoothly with Simple Methods
Created on: 27 Dec 2021 08:13
jannau
jannau
27 Dec 2021 08:13
Hello everyone, I installed the Metod drawers in my IKEA kitchen and noticed that they close quite hard and loudly. This is especially true for the larger drawers, which are often fully loaded; closing them is unpleasantly loud and feels rather rough. I am now looking for simple methods or tricks to make the drawers close more quietly and smoothly without having to modify the slides or dampers or buy expensive replacement parts. Maybe there are tips involving material inserts, adjustments to the drawer runners, or tricks that have proven effective with Metod? I look forward to your experiences and solutions!
Jaime
27 Dec 2021 10:09
With IKEA Metod drawers, a common and understandable issue is that they close relatively loudly without a soft-close feature and tend to slam harder when fully loaded. A simple and effective tip is to use self-adhesive dampers made of rubber or silicone, which can be attached behind the drawer frame on the furniture. These dampers absorb the impact energy and significantly reduce the noise. They are inexpensive, easy to find, and do not damage the furniture. It is important to place the damper so that it contacts the side or bottom of the drawer. I have tried this myself and am satisfied with the result.
toril
27 Dec 2021 12:34
Correct, using small shock absorbers is a proven method. Additionally, adjusting the guides is crucial: the Metod system rails have adjustment screws to fine-tune the end position. This allows the drawer to avoid hitting the back panel with full force. A gentler closing often results from slightly lifting or cushioning the drawer at the rear. However, the options here are limited, as these systems are not designed for soft-close functionality, which is often the best solution.
Linavin
27 Dec 2021 14:42
Interesting, but I would question the issue with the dampers: How long do those self-adhesive rubber buffers actually last? Especially with frequent use, the adhesive might come loose or the material could harden. Wouldn't it be more sensible to at least retrofit the dampers of the soft-close system? I know the Metod series is primarily designed for simple systems, but aren't there now compatible, affordable soft-close adapters available that can be installed without replacing the entire track?
Palenar
27 Dec 2021 16:27
Regarding question two: There are retrofit solutions that work without completely replacing the drawer slides. These soft-close adapters can be installed by fitting them into the existing tracks or attaching them to the back of the drawer. The challenge often lies in aligning the drawer precisely, as different load conditions affect the closing mechanism. It is especially practical to consider the drawer’s load—no damper will work properly if the drawer is overloaded. Another tip: small felt strips can be applied at contact points to reduce the impact noise. However, they only reduce the sound and do not absorb the impact energy.
Jaime
27 Dec 2021 18:53
Linavin schrieb:
Wouldn’t it be more practical to at least retrofit the dampers of the soft-close system?
I have already tried this idea myself, but the Metod drawers mostly use simple ball bearing runners that are not designed for soft-close. A complete replacement of the runners then becomes a major task. If you are looking for simple solutions, self-adhesive rubber buffers are the most practical option. For long-term comfort and a pleasant feel, however, upgrading to soft-close systems is recommended, provided the kitchen fronts and drawers allow for it.
