ᐅ How do I install IKEA Metod cabinets with soft-close drawers?
Created on: 24 Dec 2018 10:23
ploon
ploon
24 Dec 2018 10:23
Hello everyone, I am currently working on a project to assemble several IKEA Metod kitchen cabinets with soft-close drawers. I want to ensure that the assembly is not only neat and sturdy but also that the soft-close function of the drawers works optimally afterwards. My specific question is: Are there any special tips or steps to keep in mind when assembling the Metod cabinets with the soft-close drawers, especially regarding the installation of the drawer slides, adjusting the damping, and the correct alignment of the fronts? I would also appreciate any advice on how to avoid common mistakes that could affect the soft-close mechanism. I have already reviewed the IKEA instructions, but sometimes the guidance is a bit brief. Thanks in advance for your suggestions!
bupar
24 Dec 2018 11:05
Basically, assembling the IKEA Metod cabinets mainly involves connecting the carcasses, installing the soft-close drawers, and fine-tuning the dampers. I recommend the following approach:
- First, assemble the carcasses exactly according to the instructions, paying close attention to freedom from stress and squareness.
- The drawer runners must be installed cleanly and straight; otherwise, the drawer will stick later on.
- The soft-close mechanism must be mounted precisely in the specified positions.
- After inserting the drawer, roughly align the front panel first, then adjust the dampers individually.
Common mistakes include crookedly installed guides, screws that are either too loose or too tight, and imprecise front panel installation, all of which affect functionality. Check all screws afterward and prioritize precise alignment over speed.
maflo
24 Dec 2018 12:47
I’d like to share my approach to assembling Metod cabinets with soft-close drawers to ensure everything works optimally later on.
1. Preparation: Sort the components and check that all parts—especially the drawer slides and dampers—are complete.
2. Cabinet frame: When assembling, make sure the corners are perfectly square. You can check this with a carpenter’s square or a spirit level. A skewed frame will significantly affect how the drawers operate later.
3. Drawer slides: The metal slides for the soft-close drawers have small markings or pre-drilled holes that need to match the instructions. Do not tighten the screws too firmly to allow for adjustments later.
4. Install and test the drawer box: Once the drawer is in place, you can still adjust the front. Metod systems offer side screws or adjustment wheels to fine-tune the front laterally, vertically, and in tilt.
5. Adjust soft-close: There are usually two adjustment screws or controls on the dampers. Depending on the weight of the drawer and the desired opening speed, you can modify these settings.
Common mistakes I often see are uneven cabinet frames, incorrectly positioned slides, and screws that are either too tight or too loose. Therefore, I recommend taking your time with alignment and checking the function after each step.
blaki
24 Dec 2018 13:15
maflo schrieb:
Take your time when aligning and check the function after each step.
Absolutely! That advice is invaluable – better to proceed slowly and carefully than to end up frustrated with squeaky or sticking drawers later on. I personally love the smooth closing of soft-close drawers – but when they start to creak or catch, it really spoils the mood 😄.
My tip: I always install all the drawers first and test their movement before fitting the fronts. If something sticks, this way it’s easier to identify the cause. And if you have children who might turn it into a “drawer rally,” it’s even more worthwhile to hold off on fitting the fronts at first 😉.
ploon
24 Dec 2018 15:38
bupar schrieb:
Typical mistakes include misaligned runners, fasteners that are either too loose or too tight, and improper front panel installation, all of which can affect functionality.
That sounds very plausible, thanks! How can I tell if the runners are installed correctly? Are there specific measurement methods or reference marks that I should definitely look out for? My gut feeling is that I should use a carpenter’s square or a precise caliper – do you have any experience with that? Also, is there a way to adjust the soft-close system to accommodate heavier drawer weights, in case I have a particularly heavy drawer?
giabau
24 Dec 2018 16:54
Regarding the question about the installed guides: Yes, most Metod rails have scribing marks, and the instructions clearly show the exact spacing for mounting them. I recommend the following steps:
- Use a square to ensure the rails are installed straight and parallel.
- Measure from the cabinet edge to the mark with a tape measure to position accurately.
- Screw in the screws slightly at first to allow for adjustments.
Regarding soft-close and drawer weight: The soft-close dampers have an adjustable mechanism (e.g., a small slider or adjustment screw). For heavy drawers, it may be necessary to reduce the damping so the closing action is not stopped too abruptly. Lighter drawers benefit more from full damping, which prevents slamming.
Tip: Before final assembly, do several adjustment tests by sliding the drawer in empty and later loaded. This way, you can find the setting that works best for you.
