Hello everyone, I have a specific question regarding the installation of Ikea Metod kitchen cabinets. In my apartment, the walls are unfortunately not perfectly vertical, which makes installing the cabinets quite challenging. My question is therefore: What is the best approach for assembling Metod cabinets when the walls are uneven to avoid future issues with appearance and stability? Are there proven techniques, special tools, or installation methods you would recommend? It is important for me not only to get the cabinets level but also to fit the entire kitchen run as closely as possible to the uneven wall surfaces. I look forward to your tips and experiences!
chenValeri6 Jul 2019 14:22It’s best to first measure the uneven spots on the wall using a spirit level or a laser level. Then, when installing the cabinets, align them according to the lowest or most uneven point and use shims or spacers to level the fronts. Wall fixings can often be adjusted with long screws.
Hello, I understand your dilemma well, as I have experienced the same in my own projects. It is important to first take the time to measure and mark the walls precisely. A protractor or laser distance meter can help with this. To compensate for uneven walls, height-adjustable feet for the Metod cabinets and wedges made of wood or plastic are useful. You can also mount the cabinets slightly offset from the wall and cover the gaps with filler strips. Make sure the cabinets are securely fastened to the wall; sometimes longer screws and additional anchors are needed to support the weight. If you are uncertain about the structural integrity, a pre-planned frame construction, for example made of wooden battens, installed in front of the wall as a leveling support, can be very helpful.
To address your question precisely: crooked walls are a known issue with Metod cabinets, as the system is designed for flat surfaces. In general, I recommend the following structured approach:
- First, accurately measure the entire length of the wall line using a straightedge and spirit level or laser level
- Identify the most crooked point and align the first cabinets based on this reference
- Use shims and leveling plates under the cabinet feet for adjustment
- Add filler strips (baseboard trims, panels) to conceal gaps between the cabinets and the wall
- When attaching the Metod wall brackets, use sufficiently long anchors and screws to ensure secure fixing into the wall
I also consider a prefabricated horizontal leveling strip made of sturdy material on the wall useful if the tilt is very pronounced. This simplifies fastening and reliably compensates for unevenness.
Hey, I’m very familiar with dealing with uneven walls 😅! I once installed a Metod kitchen in an old apartment with quite a few irregularities. My advice: after measuring and leveling with shims, you can perfectly cover small gaps with custom-fit filler strips, which Ikea also offers – this keeps everything looking neat while still allowing a bit of flexibility.
And don’t worry about the screws: sometimes you literally have to screw in at an angle to make sure everything holds tight. In the end, it’s a combination of patience, a few extra screws, and the right visual finish that does the trick. The kitchen will still turn out great – and the unevenness basically becomes your design upgrade 😉!
Shawn38 schrieb:
If you’re unsure about the structural stability: A pre-planned frame construction, for example made of wooden battens, as a leveling base in front of the wall, can be very helpful.That sounds interesting. So far, I have only worked with wedges and filler strips. Could you briefly explain how such a frame construction is typically built and how to best attach cabinets to it? Would this solution also make sense if the wall is unevenly slanted and I possibly have several spots with different depths?
