Hello everyone, I have a specific question regarding the installation of Ikea Metod kitchen cabinets. In my apartment, the walls are unfortunately not perfectly vertical, which makes installing the cabinets quite challenging. My question is therefore: What is the best approach for assembling Metod cabinets when the walls are uneven to avoid future issues with appearance and stability? Are there proven techniques, special tools, or installation methods you would recommend? It is important for me not only to get the cabinets level but also to fit the entire kitchen run as closely as possible to the uneven wall surfaces. I look forward to your tips and experiences!
DEOLU schrieb:
Could you briefly explain how a frame construction like this is built and how to best attach the cabinets to it?Sure. The principle is quite simple and works as follows:
- Attach horizontal wooden battens to the wall, which you first align on a leveled plane (for example, using a spirit level or laser level).
- The battens serve as a new, straight mounting base for the cabinets, basically forming a frame that evens out the wall.
- If the wall is very uneven, you can support the battens at problematic spots with spacer blocks or precisely cut pieces.
- Afterwards, the Metod cabinet supports or legs are fastened to this wooden substructure instead of directly to the wall.
This way, you can deal with sections that have varying depths or are out of plumb, since you can adjust the battens and mount the cabinets level on them. The only important thing is that the construction is stable and can carry the weight of the cabinets.
DEOLU schrieb:
How can I best proceed when assembling the Metod cabinets if the walls are uneven, to avoid later issues with appearance and stability?A suggestion: Be sure to use a spirit level continuously during assembly, not just at the beginning. Some small deviations only become noticeable once multiple cabinets are connected. For that:
- Securely join adjacent cabinets together to prevent rocking
- Check the vertical alignment again after each fixing
- Use shims to fill visible gaps and keep the appearance neat
This increases overall stability and prevents wobbling or jamming later on.
