ᐅ How can the Ikea Pax wardrobe be easily disassembled for moving to a new home?
Created on: 11 Nov 2020 09:07
JONMAR
I am about to move and need to disassemble my Ikea Pax wardrobe to transport it more easily. My question is: What is the easiest way to take apart the Ikea Pax without causing any damage?
I have already removed some parts and taken off the doors where possible, but I am unsure about the best method to carefully detach the side panels and shelves. Are there any special tricks or tools that have proven effective for this?
I am also wondering if it is helpful to sort or label the screws and connectors during disassembly to make reassembly faster.
I would appreciate any advice, including potential pitfalls or important tips!
KODAN32
12 Nov 2020 08:55
Regarding removing the back panel:
The back panel of the Pax wardrobe is usually made of a thin hardboard or thin MDF, fixed with small nails. Here are the best tips for carefully removing the back panel intact:
- Use a thin, flat tool (e.g., a small prying tool or a flat spatula) and gently slide it under the edge of the back panel.
- Pry the panel away from the frame gradually in small steps to reduce stress.
- Do not forcefully pull off the panel, as it can break or fray easily.
- Alternatively, you can carefully cut along the edge of the back panel with a sharp utility knife to separate it and then order a replacement (available as a spare part from Ikea).
For transport, an undamaged back panel is very helpful because it ensures the stability of the wardrobe. So always proceed with patience.
One more tip: If you do not want to reassemble the wardrobe before taking it apart, set up your tools and workspace so you can work comfortably during the disassembly to avoid rushing or excessive physical effort.
reoleon47
12 Nov 2020 12:13
This all sounds very well thought out, great contributions here!
I think a Pax wardrobe is definitely suitable for moving, especially if you take it apart carefully. Take your time when dismantling, don’t rush! Patience really pays off.
Also: Pack everything well, sort screws and components, so you avoid frustration later during reassembly.
You’ve got this, JONMAR! By the way, have you considered using protective film or blankets for storage and transport? They protect the surfaces really well!
