Hello everyone, I recently purchased some furniture from the Ikea Brimnes series, but I am not satisfied with the plain white finish and would like to add some color to the pieces. Therefore, I have the following question: How can Ikea Brimnes furniture be color-enhanced without compromising functionality or requiring extensive modifications? I am mainly interested in practical and durable methods, such as suitable paint finishes, vinyl wraps, or other creative options that hold up well in daily use. Are there any proven approaches you would recommend? I look forward to your tips and experiences!
miAlessio2 Oct 2020 09:11Hello jon38, I’m happy to help you. To refresh the color of Ikea Brimnes furniture, I recommend a structured approach:
- Preparation: First, clean thoroughly and lightly sand the surface to prepare it for paint or adhesive film.
- Paint: Use acrylic or chalk paints, as they adhere well to smooth surfaces. Applying a primer before painting is advisable.
- Adhesive Film: For less effort, you can use furniture films; make sure the surface is grease-free so the film sticks properly.
- Furniture Handles: Replace handles with colored, patterned, or metallic ones to enhance the visual appeal.
A small tip: Always test the method first on an inconspicuous spot before working on the entire piece. This helps avoid mistakes or check how well the paint/film adheres.
If you like, I can also recommend covering the edges with colored masking tape, which makes painting easier and ensures clean lines.
Rashadmeo3 Oct 2020 13:37Hi jon38, I think it’s great that you want to spruce up your Brimnes furniture! 😊 It’s really fun and instantly changes the atmosphere of your room. Try colorful furniture handles or stick on some cool self-adhesive vinyl – you can get really creative with that! Also, chalk paint is super easy to use and gives a nice matte finish, even for beginners. Don’t get discouraged, it will definitely turn out great! 💪
To permanently enhance the color of Ikea Brimnes furniture, choosing the right materials is essential. The furniture surfaces are coated, making them somewhat more resistant, which has both advantages and disadvantages. The coating prevents paint from being easily absorbed, which makes painting more challenging but also increases the durability of the furniture.
The following points are important:
- Thorough cleaning, preferably with isopropanol, to remove grease.
- Light sanding with fine-grit sandpaper (220 grit or finer) to roughen the surface.
- Use of a primer specifically designed for smooth surfaces.
- Application of water-based acrylic paints or sprayable furniture lacquer.
- For protection, a clear sealant, usually a clear coat, is recommended at the end.
Alternative: High-quality self-adhesive films offer a flexible option but permanently alter the original surface. Selecting the correct adhesive and film material is crucial for durability and easy cleaning.
Conclusion: A methodical approach to preparation and choosing the right materials are key to achieving a durable and aesthetically pleasing result.
