ᐅ How can moisture damage be prevented in Malm furniture?
Created on: 24 Jun 2024 10:17
aurela49
aurela49
24 Jun 2024 10:17
I have a Malm bed and some dressers from Ikea that I really appreciate, but I’m concerned about moisture damage. Since I occasionally experience higher indoor humidity levels in my apartment, I would like to know: What is the best way to prevent moisture damage to Malm furniture so it stays in good condition for a long time?
I am especially interested in practical daily tips, how to integrate the furniture into the room’s climate, as well as any special care or treatment for the surfaces.
Thank you in advance for your expertise!
meGreg
24 Jun 2024 10:46
Hey aurela49,
interesting topic! 😊 Malm furniture is made of particleboard with a melamine resin-coated surface – quite durable, but not waterproof. My rule of thumb: moisture and Malm just don’t get along well.
What always helps is regular ventilation. Ideally, open windows fully for a short period to quickly exchange the air and prevent moisture from settling on the furniture.
And avoid direct contact with water! So don’t place wet cloths or damp cleaning tools on it. A simple mat or protective layer can work wonders ;-)
gregto
24 Jun 2024 11:05
Hello aurela49,
I’m happy to give you a brief overview on how to specifically prevent moisture damage to Malm furniture.
Basically, the following applies:
1. Avoid high humidity levels (optimal: 40-60%). Use a dehumidifier if necessary.
2. Ensure sufficient air circulation around the furniture – do not place furniture directly against walls.
3. Clean the surfaces carefully with a slightly damp cloth, not wet.
4. Use coasters or felt pads when placing containers on the furniture to prevent moisture absorption.
One more tip: Occasionally check the backs and interiors for early signs of swelling or discoloration. This way, you can react promptly.
If you’d like, you can describe how your apartment is ventilated and whether you’ve already experienced issues with mold or swollen furniture.
aurela49
24 Jun 2024 12:33
gregto schrieb:
Occasionally check the back sides and inner surfaces for early signs of swelling or discoloration.
Thanks, gregto, that’s really valuable advice – until now, I’ve mainly focused on the visible surfaces.
I usually ventilate the room in the morning and evening with quick bursts, but unfortunately, air circulation isn’t optimal throughout my small apartment. That means some furniture is placed quite close to the walls, though not pressed completely against them.
Moisture levels in winter sometimes seem higher to me, but luckily, I don’t have any mold. Still, I notice small swellings at the edges in some places, especially on the dressers.
How should I proceed when I see the first spots? Is there a way to repair this, or is the furniture basically already ruined?
Surela
24 Jun 2024 13:12
aurela49 schrieb:
How should I proceed when the first damaged spots become visible? Is there a way to repair them, or are the furniture pieces basically lost?
Hello aurela49,
a very good question, which I would like to answer a bit more technically: Malm furniture is typically made of particleboard with a melamine-coated surface, which is quite resistant to moisture – but only as long as the surface remains intact. Swelling mainly occurs at cut edges and corners where moisture can penetrate.
If the first spots are visible, I recommend the following steps:
1. Keep dry: Immediately dry the affected areas thoroughly and avoid any further moisture exposure.
2. Cleaning: Gently remove all loose or swollen parts (be careful not to cause more damage!).
3. Repair: Afterwards, you can use furniture repair filler or special wood fillers to smooth the surface.
4. Surface protection: Then it is advisable to apply a thin layer of protective varnish or melamine/polyurethane lacquer over the repaired spots. This prevents further moisture absorption.
5. Prevention: Transparent edge banding or edge protectors can help prevent water penetration along the edges.
However, if the swelling is extensive and the stability is compromised, repair is usually not worthwhile. In that case, replacement makes sense.
I would be interested to know how old your furniture is and whether you assembled it yourself partially, as assembly errors can affect the protection.
aurela49
24 Jun 2024 13:45
Surela schrieb:
However, if the swelling is widespread and the stability is compromised, repairing it usually isn’t worthwhile.
Thank you for the technical details; that makes sense to me. My Malm furniture is still relatively new, about 2 years old, and I assembled it myself. So assembly errors could be a factor.
The swelling has been minor so far, mainly at edges that I don’t heavily use in daily life.
What can you say about the impact of heating air? I often feel that the dry, warm air both dries out the furniture and at least reduces moisture. Does heating actually help prevent moisture damage, or can it even cause problems?
