I have a Malm bed and some dressers from Ikea that I really appreciate, but I’m concerned about moisture damage. Since I occasionally experience higher indoor humidity levels in my apartment, I would like to know: What is the best way to prevent moisture damage to Malm furniture so it stays in good condition for a long time?
I am especially interested in practical daily tips, how to integrate the furniture into the room’s climate, as well as any special care or treatment for the surfaces.
Thank you in advance for your expertise!
warrenka5724 Jun 2024 14:13aurela49 schrieb:
What can you say about the influence of heating air?That’s a good point you raise.
Heating air is usually quite dry, which can help reduce moisture in the air and thus minimize the risk of mold and moisture damage.
But it’s a double-edged sword – if the air becomes too dry, furniture and wood materials can become brittle over time, leading to cracks and material fatigue.
My advice would be to keep the humidity levels as stable as possible (ideally 40–60%), for example by using humidifiers indoors during winter. This helps avoid extreme fluctuations, which is generally better for furniture than very dry or damp conditions.
Best regards!
To be honest, I’m a bit skeptical about all the talk regarding humidity and such.
Sure, but that’s only part of the story. In the end, what really matters is how often furniture comes into direct contact with water, or if there are poorly ventilated areas caused by mounted screws and brackets.
I mean, Ikea produces millions of Malm furniture pieces, and hardly anyone experiences constant serious moisture damage. So my advice: don’t panic about humidity, but avoid water exposure and think carefully two or three times about what you put on your dressers.
Most moisture damage results from neglect, not because the living room has poor humidity levels.
warrenka57 schrieb:
Heater air is usually quite dry, which can help reduce moisture in the air
GALEO4 schrieb:
My advice: Don’t worry about humidity, but keep water away and think carefully two or three times about what you place on your dressers.I think that sums it up pretty well. You can take it easy – Malm furniture isn’t super delicate antiques, but of course, they don’t like constant moisture or wet flower vases directly on the wood.
For example, I always use small felt pads or placemats to prevent water or cold from touching the furniture directly. During the winter months, besides quick airing, I also like to ventilate for a few minutes with the window closed, carefully and continuously, to avoid losing too much heat and dry air.
So in the end: be mindful when caring for your furniture, use simple everyday tricks, and everything stays looking great :-)
