ᐅ MALM Furniture and Moisture – What Is the Best Way to Handle It?
Created on: 8 May 2020 09:23
TENUNUHello everyone,
I am currently facing an issue with slight moisture appearing on my IKEA Malm furniture in the bedroom, especially along the edges and partly on the back of the drawer fronts. The indoor air quality is fairly normal, but I often experience slightly higher humidity levels in winter. My question is: What is the best way to minimize or even prevent these moisture damages without harming the furniture? Are there any specific tips for dealing with moisture on Malm furniture, especially since it is made of particleboard with a foil laminate?
I would be interested in advice on preventive measures, what to do if moisture marks are already visible, and whether any particular care products or methods have proven effective. Thanks in advance for your suggestions!
Hey, this is a great topic, especially since MALM is commonly found in many bedrooms and moisture is often underestimated 😊!
First of all, it’s important to identify the direct source of moisture – it often helps to air out the furniture several times a day (open windows briefly to ventilate, then close them again). MALM is quite sensitive to swelling particleboard, so it’s best to avoid letting the surface stay damp for extended periods.
If the edges start to feel soft or swollen, it’s usually already too late, and replacing the affected parts is recommended. Otherwise, so-called moisture absorbers or even some baking soda in drawers can help reduce local humidity.
Oh, and a tip: MALM and other IKEA furniture don’t like water vapor, so it’s good to heat the room regularly when possible and avoid wiping or cleaning with moisture that stays on the surface. Otherwise, mold will be the only one happy ;-)
Hello TENUNU,
to assist you best, it would first be helpful to know whether the moisture problems occur only occasionally or if they are due to a consistently humid indoor climate. MALM furniture is made of particleboard with a foil coating, which provides some barrier against moisture but is often particularly vulnerable at the edges, as the sealing there is frequently not optimal.
Procedure:
1. Measure the humidity (e.g., with a hygrometer). Ideal values are between 40-60% in the living area.
2. Keep furniture slightly away from walls, if possible leaving a few centimeters (inches) of space to allow air circulation.
3. For edges that are already swollen or discolored, there are special wood protective varnishes or sealants suitable for particleboard. The surface must be completely dry before application.
4. Avoid using water or damp cloths directly on foil surfaces, as this can loosen the foil and damage the particleboard underneath.
5. If necessary, use moisture absorbers; regular ventilation is also essential.
A further note: If high humidity levels in the room occur frequently, the causes (ventilation habits, furniture near bathrooms, plants, etc.) should be checked and adjusted.
Could you possibly share your exact room temperature and humidity values? This would help with the assessment.
Procedure:
Hello everyone!
I really like this topic because I recently had a similar issue with a MALM wardrobe and was able to fix it thanks to a few tricks!
My tip: moisture absorbers, which you can find at any hardware store, are real lifesavers! They draw moisture out of the air and help prevent furniture from getting damp. I placed one directly to the right of the wardrobe, and it made a big difference. 🙂
Also, always remember: when cleaning, do not use overly wet cloths. It’s better to wipe damp and then immediately dry the surface. This avoids minor water damage.
If the edges have already swollen, don’t worry – sanding and applying new paint often helps. But that’s more of a job for DIY enthusiasts. 😉
So keep at it, it’s worth it!
Regarding the situation: Particleboard furniture, such as the MALM series, is inherently sensitive to moisture, especially at the edges without continuous sealing.
Technically, water penetrates the particleboard matrix, causing swelling and loss of structural integrity. Therefore, the most important measure is to avoid or minimize exposure to moisture from the start.
In practice, I recommend:
- Using dehumidifiers when indoor humidity is high
- Keeping a distance from exterior walls, which are often cold and damp
- Protecting the edges with clear sealants available from woodworking suppliers
- Regularly inspecting for any minor surface damage
Additionally, average climatic conditions during the same season are a significant factor influencing moisture exposure.
Could you please provide the exact location of the room? {} (e.g., proximity to a bathroom or exterior wall) and whether any visible material changes are already present?
TYRELL schrieb:
Could you please provide your exact room temperature and humidity levels? That would help with the assessment.Thanks for asking! The room temperature is usually between 19 and 21 degrees Celsius (66 to 70 degrees Fahrenheit), and according to the hygrometer, the humidity is mostly between 55-65% during winter, rarely going above or below that. The room is on an exterior wall with a window and no adjacent bathroom.
Regarding visible changes, the edges have become a bit softer, especially on the lower drawers, but so far there are no visible swellings or peeling of the laminate.
I’m also not sure whether I should seal the edges, as I don’t want to damage the material.
