ᐅ How can I permanently stabilize MALM furniture?
Created on: 21 Jul 2023 09:13
Fakau38
Hello everyone, I already have several MALM furniture pieces from Ikea at home and generally find them quite stylish and practical. However, I often notice that the stability becomes an issue after some time, especially with larger dressers and desks. My question is: What proven methods, tools, or materials are available to permanently and effectively improve the stability of MALM furniture without compromising its appearance or functionality? I am particularly interested in how to identify typical weak points and reinforce them specifically, such as joints, back panels, or the anchoring to the floor. I look forward to constructive tips and practical experiences. Thank you in advance!
Deandre
21 Jul 2023 12:44
Fakau38 schrieb:
If I replace this with a plywood board, what thickness would be ideal?
Plywood boards with a thickness of 6 to 8 mm (1/4 to 5/16 inches) are ideal – sturdy enough but still lightweight. It is important to cut the board precisely to fit.
Fakau38 schrieb:
Mounting options without visible screws
One option is to countersink the screws on the inside. You can pre-drill holes, sink the screw heads into small recesses, and fill these with wood filler or a color-matched cover cap. Additionally, so-called corner braces mounted from the inside are hardly visible and increase stability.
Regarding drawer slides: they are usually fixed with small screws. Check if they are secure; if necessary, you can use longer or thicker screws. Applying liquid wood glue in the mounting area can also help if the material has become soft.
One note: avoid over-tightening the screws, as this can damage the material.
Wesley
21 Jul 2023 13:15
Deandre’s tip is worth its weight in gold! Also, you can fill the screw holes for the back panel with wax or putty that matches the color, which looks much neater 🙂
Regarding drawer slides: If they wobble a bit, lubricating them with silicone oil or Teflon spray helps. Of course, don’t use too much, or it will attract dirt, but this makes them operate more smoothly and provides stability when pulling and pushing.
And honestly: If nothing else works, try removing the drawers, check all the screws on the slides, and replace them if needed. Sometimes, small repairs can work wonders!
jeix9
21 Jul 2023 13:50
Multiplex 6-8 mm (1/4–5/16 inch) fits. Countersink screws and use filler. Tighten drawer slides and lubricate if necessary.
Lilau
22 Jul 2023 08:22
I also spent a lot of time thinking about this issue because my Malm dresser started wobbling significantly on the floor after a few years. I didn’t want to just patch it up; I wanted to stabilize it as permanently as possible.
I screwed a thin strip to the inside of the back panel (discreetly, since it’s hidden) and completely replaced the backing with plywood panels. I attached the panel using 3-K screws, which I later covered with wood filler.
Be warned: this takes time, but it’s worth it. The dresser has been rock-solid for a year now, despite daily use.
One more tip: if your furniture stands on laminate flooring, place felt pads underneath. This cushions small movements and greatly reduces wobbling.
bauku
22 Jul 2023 08:55
This is brilliant, so many great tips have come together here! :-)
I wanted to add: If you also install a clamp rail or tension rail on the inside, the load is distributed even more evenly. I did this on my MALM desk and it prevented warping.
Also, it is often the combination of several measures that is most effective – replacing the back panel, checking screws, using glue, adding furniture sliders underneath, and so on. The piece of furniture is basically stabilized 'from the inside.'
I’m glad to have found such a lively discussion!
Fakau38
22 Jul 2023 09:22
Thank you all, the experience reports and tips are very helpful.
I will probably try cutting an 8mm (0.3 inch) plywood panel and attaching it with countersunk screws and putty. I especially like the idea of using felt pads, since my furniture is on laminate flooring.
At the same time, I will check the screws on the drawer slides and replace and lubricate them if needed.
Question for the group: Does anyone know a good source for suitable plywood panels (ideally with a cutting service)? I want to keep the effort as low as possible.
