ᐅ How can IKEA PLATSA furniture be discreetly mounted on the wall?
Created on: 17 Dec 2022 08:37
Ixmaus
Ixmaus
17 Dec 2022 08:37
I am currently facing the challenge of attaching my new Ikea Platsa furniture to the wall as discreetly as possible. My focus is not only on safety and stability but also on keeping the mounting materials as hidden as possible, avoiding any visual distractions—especially on the sides and top, where fasteners are usually visible. I have already considered the standard wall brackets from Ikea, but I find them visually unappealing, especially when viewed up close.
Since PLATSA consists of modular cabinets, I want to avoid mounting points that disrupt the design or cause unnecessary damage to the wall later on. Special anchors or concealed fasteners might be an option.
Does anyone have tips or experience with mounting PLATSA furniture on the wall using the most discreet methods? I would also appreciate advice on which tools or mounting materials work best and if there are any tricks to conceal the fasteners. I am also open to suggestions for alternative solutions that hold well and remain unobtrusive.
Thanks in advance for the support!
DULIS
17 Dec 2022 09:02
it’s best to use the original wall brackets from Ikea and cover them with white caps. Alternatively, you can use flat metal brackets and paint them to match the wall. The important thing is to always position the holes in the wall correctly, meaning into the wall plugs.
Making the fixtures completely invisible will be difficult, as the furniture still needs to be securely supported.
Keatondra
17 Dec 2022 09:59
Hello Ixmaus,
I understand your concern well. The goal is to make the fastenings "invisible" without compromising stability. Here are a few tips from my experience:
- Use countersink screws or countersink bits so that the screw heads are recessed into the wooden panels and can be concealed with matching covers or wooden wedges.
- For the wall itself, I recommend cavity anchors for drywall, or solid anchors for masonry walls.
- You can also use concealed furniture fittings, which Ikea does not usually supply but are available from specialist retailers.
- Another option is to mount the PLATSA modules slightly offset from the wall and then place a thin panel or strip in front to hide the fastenings.
It is important to carefully consider in advance where and how much weight you have, and plan the fastenings accordingly. Most furniture is designed for wall mounting to prevent tipping.
If you want, I can also provide some product names that I have had good experiences with.
Roberta
17 Dec 2022 10:23
I recommend attaching the PLATSA elements to the wall using screws and flat steel brackets. You can paint these brackets white to match the wall color. For a discreet look, countersunk screws with matching caps work well. It is important that the supports are strong enough and that you choose wall plugs suitable for the type of wall.
Ixmaus
18 Dec 2022 07:45
Keatondra schrieb:
You can also use concealed furniture fittings that Ikea doesn’t include by default but are available separately from specialist retailers.
That sounds interesting. Could you give me some product names or terms I should be looking for? So far, I’ve mostly checked directly with Ikea, but they don’t seem to offer any “concealed” fasteners for PLATSA, at least I haven’t found any.
Keatondra schrieb:
Another option is to mount the PLATSA modules slightly offset from the wall and then add a thin trim or molding in front to hide the fasteners.
I’m not sure if that fits my interior style. Do you mean something like a continuous shadow gap? Or more like a visible cover strip? How did you solve this with your furniture?
Thanks in advance!
NOAHSAU
18 Dec 2022 10:13
Ixmaus schrieb:
Could you name some product types or terms I should look for?
If you want, you can search for "concealed furniture connectors" or "concealed corner connectors." These components are hardly visible when used correctly.
Ixmaus schrieb:
Or rather a visible cover strip?
I would see that more as a design element; it’s not a bad thing. Being unobtrusive isn’t always necessarily better – often the design even gains character because of it.
However, for the very best appearance, many simply replace standard wall brackets with custom-made solutions from metal fabrication or use magnetic fasteners if the weight allows it. If the look of the wall brackets matters, that’s something to consider.
