ᐅ How can Ikea Pax be used as a wardrobe in small apartments?
Created on: 28 Sep 2024 16:07
rajkopa
rajkopa
28 Sep 2024 16:07
I’m moving into a rather small apartment soon and am looking for a practical solution for a wardrobe. My question is: How can the Ikea Pax wardrobe be best used in small apartments as a wardrobe, so that it makes efficient use of storage space without appearing too bulky? I’m especially interested in how to optimally organize the interior, whether certain modifications like sliding doors or different internal modules are useful, and what to consider when dividing the space so that the wardrobe doesn’t overwhelm the room despite its size. Who has practical experience or tips, especially for special challenges like limited floor space or sloped walls? Thanks in advance for your answers!
Domau0
29 Sep 2024 11:23
Hello rajkopa,
First of all, I find your question very practical. The Ikea Pax system is indeed one of the best solutions for small apartments when it comes to wardrobes, thanks to its modular design – provided you plan the interior carefully.
Regarding size, it is advisable to go for the maximum height (often up to 236 cm (93 inches)) to fully utilize the vertical space. Especially in small rooms, height can compensate for limited floor space. Important: If the ceiling height is lower, consider having the modules cut to size or choosing smaller variants to fit.
For doors, I prefer sliding doors. They are somewhat more expensive but save a lot of space because they don’t require clearance to open outward, which is very helpful in tight rooms. However, I recommend a sturdy track system, as low-quality tracks can cause problems depending on the load.
About the interior layout: it’s best to combine hanging rails with shelves at the top for folded clothes. I use drawers for smaller items like underwear and socks.
It’s important not to overload the wardrobe with too many compartments in small floor plans, so you maintain an overview and ensure easy access. Shelf compartments for shoes or storage boxes also help optimize use.
One more tip regarding walls: If one side is sloped, you can’t use a standard Pax module, but you can, for example, install shelves without a back panel or combine open elements, keeping the wardrobe flexible.
What seems most important to me is to measure the room precisely first, considering doors and windows, and then experiment with whether more width or height makes more sense than a deeper option. Additionally, some Pax planning tools online offer good preliminary visualizations.
If you like, share some details about the room size and whether, for example, there is a partition wall or niche – then I can give you more tailored advice for your situation.
flo-Theres
29 Sep 2024 18:42
Before discussing features for small rooms, I would like to briefly add that Ikea Pax is very suitable for customizations, which can be a key reason to use it in small apartments.
For small apartments, the most important point is that the wardrobe must be as functional as possible and not take up unnecessary space with depth. The wardrobe typically comes in depths of 35 cm (14 inches) and 58 cm (23 inches) – the 35 cm version is narrower but often too shallow for pants and jackets. You need to consider the type of clothing you want to hang.
Sliding doors, as already mentioned, are very practical, and I recommend the version with a mirror because it visually enlarges the room.
Regarding the interior layout, I have had good experiences with adjustable shelves and a combination of different drawers to store accessories and smaller clothing items efficiently. This reduces clutter and creates an organized system.
Another tip is to make use of the cabinet depth by using slim boxes or organizers that are precisely sized.
Finally, before purchasing, I would always measure the room carefully and consider how much free space is needed in front of the wardrobe – 60 cm (24 inches) is ideal; less is possible but can become impractical when opening the doors or drawers.
GiRoyce
30 Sep 2024 09:15
Hello rajkopa,
your question is really important because smart use of the Ikea Pax system in small apartments can significantly improve living comfort.
First of all, the biggest advantage of Pax is its flexible interior, allowing you to customize the space according to your needs. For narrow hallways or small rooms, I definitely recommend sliding doors. They truly save space, and if you add mirrors, they create an open, airy feel.
Regarding the interior layout: if the wardrobe will serve as the main closet, a good combination of hanging rods and shelves is ideal. For small spaces, I often use several shorter hanging rods, each for different types of clothing (e.g., shirts, pants). This keeps things organized and easy to find.
Additionally, baskets and boxes that fit precisely into the compartments are recommended, providing flexible storage for accessories or shoes.
If you have limited floor space, you might also consider placing a Pax system in a small corner or using it as a room divider. There are special corner modules or open shelves you can combine to increase storage without making the room feel cramped.
A small tip: ensure there is enough light. If in doubt, it’s worth installing LED systems inside or using indirect lighting to better illuminate the interior.
If you like, we can also discuss which specific clothing items you want to store, so I can suggest a personalized interior layout.
KNUTGI
1 Oct 2024 08:52
Hello!
I find this discussion really interesting because many people immediately think of space issues when it comes to IKEA Pax wardrobes and small apartments, but with a few tricks, you can get a lot out of it.
Domau0 schrieb:
When it comes to doors, I actually prefer sliding doors. They are a bit more expensive but save a tremendous amount of space
Absolutely right! In small apartments, space is king. If you also add mirrors to the doors, the room feels twice as big.
flo-Theres schrieb:
The wardrobe typically comes in 35 cm and 58 cm depth – the 35 cm version is slimmer but often too tight for trousers and jackets.
The 35 cm (14 inch) wardrobe is like a narrow door gap in the closet – not very luxurious, but if you roll your clothes instead of folding them, it can actually work very well and save a lot of space.
One more tip from my experience: if possible, see if you can put the wardrobe on casters. This makes cleaning underneath easier and allows you to move it when needed to use your space more flexibly.
All in all: fill it up with clever interior organizers and enjoy the flexibility that Pax offers. It’ll work out fine!
